Hey
Two weeks ago i installed a screamer pipe on my stock turbo [for shit n giggles] but after it was on when i boosted it i could hear a high pitch spool noise like from a upgraded turbo. I was told it was my turbo dying by a friend. Today i put my stock dump back on and the sound was gone, do you guys think there is a problem?
What should I be looking at, intake side or exhaust side of the turbo? and what specifically should i look out for?
https://www.sau.com.au/forums/topic/346353-r34-gtt-turbo/
Pretty sure it would've been an exhaust leak. Most likely the turbo -> dump connection. Those bolts are common to rattle themselves loose, I reckon 1 or 2 of those might've been loose, then when you put the dump back on you tightened them up better.
Do you remember any of the bolts being loose when you put the stock dump back on?
Maybe have a look at the turbo intake piping and the cooler piping, might have a leak.
Does the car idle and boost fine? no missing or anything?
https://www.sau.com.au/forums/topic/346353-r34-gtt-turbo/#findComment-5577170
just went to fill up and get food and i could hear clicking noises when it started to spool and loud clicking on boost.
the car is my daily, should i still drive it carefully or just leave it until i change the turbo?
https://www.sau.com.au/forums/topic/346353-r34-gtt-turbo/#findComment-5577189
it is off, only had it on to screw around for abit. put my stock dump back on yesterday and i can hear the clicking/ticking noise with the stock dump on. its not super loud but its pretty noticeable
anyone tell me if its safe to drive the car or not? its my daily and i have no other car =\
https://www.sau.com.au/forums/topic/346353-r34-gtt-turbo/#findComment-5577351
it made the ticking noise for a month before i change the dump. its just gotten louder since i changed the dumps.
i have a spare gasket for my dump but its one of those crappy paperish ones. should i just put some gasket glue in it and see what happens?
https://www.sau.com.au/forums/topic/346353-r34-gtt-turbo/#findComment-5578014
