$33,000
Maybe intrested in swaps + cash
Fresh engine 2 events since rebuild aprox 5,000km
Car currently running 365awkw with over 1400nm toque
Current tune is for mid range power delivery will make 400kw on power tune.
Everything has been done that needs to be done and all parts are basically new or are new!
Car has current SA rego
Comes with lots spares and std parts like std exhaust system.
Car as been modified from standard by myself and I have been the first owner of the car in Australia.
Currently all stickers have been removed and side skirt (left) and front bumper are having some paint done.
Top competitor in legend of the lakes hill climb also took out the overall dyno challenge at autofest 2010 Mount Gambier.
Car has barley been driven since build and is going to waist. Car was built on the basis of doing hill climbs and some track work but never seen a track yet.
Engine
Arp main bolt’s
Arp head studs
Arp rod bolts
Tomei Metal head gasket
Tomei Metal intake gaskets
Tomei Metal exhaust gaskets
ATi 1000hp balancer
Trust Oil pump
Tomei oil restrictor
Eagle rods
CP pistons
ACL race bearing throughout
Trust sump
Gready under drive pullys
N1 water pump
Nismo thermo stat
SARD 800cc
Head ported and polished
Tomei poncams B
Tomei pro double valve springs
Tomei titanium valve retainers
Nismo fuel regulator
Silicon high temp water hose set
HKS twin spark ignition
Gready solid radiator hoses
Gready oil cooler/ filter relocation
Custom hard piping kit intake/cooler
CoolingPro Intercooler
Blitz dual bovs
Twin Z32 Air flow meters
PFC Pro version with launch control and ignition cut
Braided turbo oil and water lines
Yellow jackets coil packs
HKS cam gears
OBX split dumps
Std turbo manifolds with major porting
Garret -5 turbos
kokamoto race twin 3" pipes tuned length from dumps back
justjap circuit oil catch can into a secondary custom catch can
Apexi air filters
Custom 3 core alloy radiator
Custom sure tank with bosh 044
Drivetrain
Nismo Engine mounts
Nismo Gearbox mounts
custom cusco 30mm swaybars
project D rear cradle solid bushes
project D steering rack bushes
Twin place ORC 702 clutch
Nismo short shifter
Rear adj upper camber arms
Upper front adj camber arms
Hardline caster rods
Hicas lock out bar
Front Two peice slotted rotors
Slotted rear rotors
Yellow stuff pads all round
Project mu drift handbrake pads
Braded brake lines all round
Cusco brake stopper
Tein coilovers with full in cab control
Rear LSD shimmed
Interior
6 point molly bolt in cage with full padding wrap
Nismo 320 dash
Nismo Gear knob
Fire extinguisher
Quick release steering wheel hub
Momo race wheel
Defi Gauges Oil temp/ Water temp/ Boost bar
Led shift light
Greedy turbo timer
Profec b boost controller
Exteriour
Top secret carbon rear defuzer
F1 carbon mirrors
BeeR carbon rear spoiler
Top secret carbon bonnet
Top secret front splitter
Greedy cooling pannel
Tomei headlight air duct
Zigen 18x9.5 rims on 265x35x18 semi slicks advans
Spare sprint slicks dunlop 18x35x250 (hillclimbs)
https://www.sau.com.au/forums/topic/346358-r33-gtr-1998-ser-3/
Don't think it would be to hard,
change the exhaust to STD which comes with,
change afm's and ecu to STD for emissions which it comes with,
change bonnet comes with STD bonnet,
change spoiler blade from BeeR to STD blade which comes with it,
change mirrors to STD which come with,
take bolt in cage out,
umm that's about it and you should be ok has. About the only thing I don't have is the STD airbox but have everything else original from the car.
I am located in Melbourne but car is located back in my home town Penola in SA,
I have driven the car a total of about 5 times this year and has always been garaged under a cover.
The only reason the car lives there and not here is because i have no where to secure park it, on serious intrest im happy to drive it up to here to Melbourne or to Adelaide.
Also engine was built a year ago by Protek Automotive in Preston and last tune was done 3 months ago with a new HKS twin spark system.
Also this is a ser3 r33 gtr so it has the extra bits std,
tuffer gearbox
xeon headlight
red interiour inserts
dark carbon instumental pannels
n1 front bar intakes
this was the last year they where made 1998
Edited by Travis Trayhern
call or msg 0416250596
Hi, Travis
Very nice street and track car!! wish I came across your car earlier before I start building a full on GTR33 track car.got a collection of GTR 34, NUR, GTR33, Stagea RS260, RX7 S8 RZ etc,etc.may be we can work out a deal. I have a work shop and storage warehouse in Campbellfield and Altona for my toys.come and have a look. will call you on your mobile.
chers
Alex 0433878905
JAK Motorworks
21 Thornycroft St. Campbellfield Vic. 3061
  • 2 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
