Yeah must be different as in WA we don't need to display it. In fact we don't get the sticker anymore. It saves the government a lot of money and it is good for the environment.
Yes, Mikhail. In WA, we don't get rego stickers anymore to stick. I also heard we can even get fined for leaving the expired rego sticker still on the front wind screen.
Edited by Victor.T
  • Replies 46
I got pulled up in my sisters 350gt once.
Male cop asked me if the car was stolen, why I had pink number plates, and why there are 20inch rims on it.
I said Its my sisters, I'm not stupid enough to gutter rash 20" Konigs.
he laughed and said simply a good day to you.
Got stopped by a boose bus the oder nite. For the record my car is extremely low. Cop 1st looked at my 8000k HIDs but didnt say anything to me. He then asked me for my drivers license . While reading it he proceed to the back of the car shined his torch in the rear privacy glass. Still didnt say anything. Then looked at my rear wheels and tried to put his hand between the rear tyre and fender. He couldn't even get a finger in der , so he asked me " How low is ur car". I said im not sure but its on coilovers. He didnt know wat that was so i said adjustable suspension. He said its too low . So i said no worries Sir il change it i didnt know and gave him a story about how i didnt expect the car to drop so low. He said yea u jus have to b able to get a finger between the tyre and fender. He then proceeded me to another officer who breathalised me and did a license check. It was all good and i was allowed to proceed scrapping my exhaust and front bumper in a few pot holes. ( they picked the worst place to do the checks). Also wat really helped me was the manner in which i spoke to them every answer of mine was "Yes Sir no Sir", have a guud nite Sir.
Really helps wen u know u cud b a risk of a yellow.
Steve, that was the closest you can get into trouble (Except they bring out a tape measure and you are screwed, together with your low hanging exhaust). The way you conducted with the officers was the best way too, and I think that helped you.
Anyhow, you should raise it up abit, now that you got checked once. Lucky you. :)
Edited by Victor.T
Yea man im doing a wheel allignment tomoro. Ive asked them to also raise it in the rear about 10-12mm.
Cool Steve.
I don't think 10mm-12mm is not yet enough though (At least for a fat finger. :P ). 16mm-18mm should be good and safest.
Let me know how it goes. Kinh got his car all sorted out, so we can catch up this weekends. :)
Edited by Victor.T
  • 2 months later...
My number 2 experience:
(25-03-11) I went through a booze bus again at night and was first on the queue (again. :P). Young officer went through a normal procedure of random breath test with me.
After that, he asked for my driver's license. He looked at it and said "So you are not on P-plate." I said "No, sir". He looked at my rims and ride height and shone his torch into my rear seats where my brother was sitting. He asked him if he was wearing his seat belt because his shirt was covering it. :P
No problem after that. He was ok. ;)
Edited by VNS 24
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
