It's in.. OMG it's in..
Yeah it really is that simple.. shouldnt need a tutorial to see how the piping and coil pack cover comes off.. Then undo the 2 bolts holding the coilpack on.. Undo the clip for the wire.. Replace.. Reverse to put back on..
You can't really wreck anything.. Just ensure the piping is back on correctly and sealed..
Edited by .:: GimpS-R34 ::.
Had a look but couldnt find any tutorials does any1 know if this is hard to do. simply because the throttle bidy sits right over the top of he engine cover. Some help woyld be great cheers
Same as changing spark plugs pretty much.
http://www.skylinesaustralia.com/forums/RB...ark-t42819.html
Scroll down in that topic, someone has re-added pictures.
Edited by Dani Boi
change the plugs while your there aswell
Cheers fella but what plugs should I use for s1 front mount pod 7psi Bosch 040 and what should they be tapped at and also can I buy pre gaped plugs for what I need to suit My mods.
    • Let's face it. 90s turbo 6 with 80s tech in it is not going to be the thing that runs as clean as a whistle.
    • No. See below. No. In the specific case of Enthusiast, the wording in the PDS says, explicitly, " We will not pay any claim on a Vehicle with any Modifications not agreed by us and not listed in the Schedule. This includes any Modifications or the fitting of a device that contravenes the requirements of the Australian Design Rules [ADRs] or where allowed, the Australian Vehicle Standards Rules [AVSR]." The 2nd paragraph needs to be read in a different tone of voice from the 1st. The two concepts are connected, but they are two different concepts. The 1st says your mods must be listed and agreed with us. The 2nd effectively says "we won't pay if any mods are not legal". The way that it has been written in more general insurances for a long time has been that if the mod contributes to the accident then you're shit out of luck, but if the mod didn't contribute, then you'll probably get away with it. With "probably" being a very flexible term, and being an insurance company, better left untested than hoped on!
    • I'm not surprised, I favour a bit of a richer tune which for sure isn't helping the emission numbers.
    • Overboosting is more likely a function of whatever boost controller you are using than the actuator. "Overboosting" is a feature of cheap boost tee type control. If you don't want to see peaks of overboost, you have to set it to not produce them. And that then means you don't run as much boost as you might like elsewhere. That's just life. Electronic boost controllers can generally be set to do a much better job of managing the peak boost.
    • Had a good chuckle because it is listing THC g/km. Though it is not tetrahydrocannabinol but total hydrocarbons. Interesting how the numbers seem so much worse compared to Greg's big V8.
