-g1 link plug and play for rb 25 det software gts o 09 jul 2001. with 2.5 bar map sensor perfect for getting rid of shitty afm!
-r33 smic in good nic (black)
-r34 smic in good nic (black)
-r33 gts t fuel pump in good working order
-standard springs
-r33 gst t series 2 afm done 93 384 kms
-r33 gts t series 2 gearbox done only 93384 kms
-r33 gst t series 2 super spark coil packs 2 weeks old perfect cond!
-r33 gts t high flow k and n panel filter in very good cond not that old
-r33 gts t non turbo exhaust manifold
-r33 gts t series 2 turbo with exhaust manifold complete setup done only 93384 kms minimal play never boosted!
-rebuilt r33 gts t alternator all new parts
got more things but cant think just ask me !
https://www.sau.com.au/forums/topic/346444-r33-stuff-heaps-of-random-shit/
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
