Amplifier Bar
Guest trikdoutbuketofshit
shit eh, sounds like I should pack some heat lol.
So I should be safe wearing my nike shocks???? I hate wearing my faggy black going out shoes. Only wear em if I absolutly must.
Learn some taste dude, Amps/Capitol has better music than most clubs these days. Not like all this r'n'b and hip hop flith that people call dance music.
p.s. AM bar for me anyday...
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5578570
LOL tramplifier bar. I went there when I was younger, place is just straight heinous now. Wannabees looking for fights, Juvies causing a scene... to sum it all up...
You just described every 'club' or 'bar' in Perth these days. I can't go out these days and not feel like almost every other guy is looking down on everyone else and trying to find a reason to start a fight to win over some broad minded person's approval. Then the broad minded persons are just showing off as much skin as possible, to get in touch with a man's heart's (read: penis) ability to give free drinks. Then they winge when they get cracked on. Simple females: if you don't wanna be cracked on, don't dress like a broad minded person!
/rant.
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5581999
/rant.
What the hell happened last time you went out?
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5582466
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
