Selling a fully built RB25det, this is a proven combo and has only done about 10,000kms. With its current setup using only a garrett gt35r, vipec ecu and supporting bolt ons it puts out a conservative 604rwhp.
This engine includes:
Tomei 264º 10.5mm lift inlet and exhaust cams
Tomei type B valve springs
Tomei adjustable cam gears
Fully ported and polished head
ARP 2000 12mm head studs (head and block drilled and tapped to take the larger studs)
Arias forged pistons
Spool H beam conrods
ARP 2000 rod bolts
ARP 2000 main studs
ACL race bearings
N1 oil pump
N1 water pump
Gates racing belt and tensioners
Fully blue-printed and balanced
Probably other stuff i cant think of at the moment also. Moving onto the next project is the only reason for the sale and the engine is still in the current car. The parts and machining alone add up to 20 000, asking for 10 000neg.
Genuine buyers only please call 0414 186 335.
https://www.sau.com.au/forums/topic/346458-built-rb25det-for-sale/
Hi PHT33
sent you a PM.
my work hours are little all over the place to call during the week is it fine to work on weekend or just let me know what time is good to call.
any extra info regarding to the engine build more photos
would be awesome.
very interested
Call anytime, it will be alot easier to talk about all the work that has been done on this engine over the phone rather than type it all. If you want me to call you pm me your number, if youd prefer.
Guest
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
