I tested with one of my many test accounts also, just in case it was permissions.
It's not that either, im using the same broswer as you are.
You need to disable all add-ons, delete/purge all temp/cache, reboot router and ensure any virus protection is turned off.
Sorry mate but I can't help you anymore than the above, it's your end.
https://www.sau.com.au/forums/topic/346495-sau-30/page/21/#findComment-5643040
I tried to send a PM to a member, but their inbox is full. so i clicked 'save (send later)' or whatever that option is called.
I assume it's supposed to save the message to the drafts folder for later use. but it doesnt seem to save it anywhere.
https://www.sau.com.au/forums/topic/346495-sau-30/page/21/#findComment-5646982
Hi Guys
A sujestion for the Rep system.
Somewhere off peoples profile page or their posts, you could have a summary of the posts that were awarded Rep points +'ve & -'ve (bit like ebay),
that way we can see if the Rep is earned or not,
call it 'The best & worst of' page
Keep up the good work
Bundy
https://www.sau.com.au/forums/topic/346495-sau-30/page/21/#findComment-5658012
Latest list
- Signature/Profile sizes not being “scaled” correctly:
Eg below. You can see the large pic goes under the page skin, this occurs fairly often
Profile: http://www.skylinesaustralia.com/forums/user/42272-don-dada/
- Forum Server/System clock is out by 1hr. Posts made @ 5pm, say 4pm. Its screwing with the "latest posts" feature I think.
- Trader rating viewable from threads
- SA Club user bars (Exec are fine, Club are not working)
- Remove reputation system
- “Report Post” button does not work, spits out error
- 10 post restriction before PM, has been removed. Needs to be reinstated. Already had spammers attacking the forum.
- Signature size limits not working
- View new content is not in sync/ordered at all. Sometimes the "new" stuff on page 1 can be 2-4 days old.
C is having a look over the next few days.
https://www.sau.com.au/forums/topic/346495-sau-30/page/21/#findComment-5662329
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
