R34 Gt-T 100K Service Kit And Other Parts..
100k service kit I don't have the car anymore so no longer required: rb25det neo water pump, gates timing belt, tensioner bearing, idler bearing, 3x Ancillary belts
post-47337-0-94923400-1291524979_thumb.jpgpost-47337-0-36269200-1291525011_thumb.jpgpost-47337-0-72578400-1291525052_thumb.jpgpost-47337-0-98687800-1291525128_thumb.jpg
$470
Cold air box for R34 Gtt I belive it fits R33 too only trial fitted
$90
R34 A'pillar pod few marks
$60
R34 manual steering wheel suit re-trim
$40
All parts located in Adelaide would prefer pick up but will post at buyers expense.
Pm me or sms me on 0433348748 for further info..
Also - do you have the airbag for the steering wheel?
No air bag just the wheel
the r34 @ kudos motorsports.. http://www.kudosmoto...6dett-p-51.html
they only asking like 420
The kit in the link is for a GTR, Their kit for the Gtt starts at $498 plus $77 for the Ancillary belts
ill take the wheel.
pm me your number ill pick it up
cheeers
pm'd
  • 3 weeks later...
  • 3 weeks later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
