Time to move onto a new project to give me something to do in the garage again apart from just drink beer.
For sale is my PHT33, a 600rwhp monster. A Mercury Motorsport tuned car with more power than you will know what to do with. This car has been developed to be a fully reliable street driven car. For example it only uses 10litres per 100kms. The car includes:
Fully built RB25det
Arias pistons
Spool h-beam rods
ARP 2000 12mm head studs
ARP 2000 main and rod studs
ACL race bearings
N1 oil pump
N1 water pump
Gates Racing timing belt and tensioners
Ross Metal Jacket 1000hp harmonic balancer
Tomei 264º 10.5mm lift Inlet and Exhaust camshafts
Tomei type B valve springs
Tomei adjustable cam gears
Fully ported and polished head
Nitto headgasket
Genuine Greddy inlet plenum
Billet 80mm throttle body
Custom Mercury Motorsport intercooler piping
100mm front mount intercooler
6 Boost exhaust manifold
50mm Tial external wastegate
Garrett GT35R w/ 1.06 a/r exhaust housing
Custom 3" dump pipe into full 3" exhaust system
Splitfire coilpacks
HKS Twin Spark
1000cc Injector Dynamics injectors
Billet twin entry fuel rail
Tomei fuel pressure reg (with dash mounted fuel pressure guage)
2000hp Mercury Motorsport fuel system
Walbro lift pump
Mercury Motorsport external surge tank
Twin Bosch 044 feed pumps
ViPEC ecu
probably extra items, so many to list...
Exterior
Custom House of Kolor Ice Violet Pearl paint job
Customised Veilside VS1 front bar
JUN sideskirts
Customised 400R rear bar
Asking $25000 for her. Serious buyers please call 0414 186 335.
https://www.sau.com.au/forums/topic/346557-600rwhp-r33-for-sale/
does it have coil overs? what suspension set up do you have on it...... also can you post up a couple of interior pics.... cheers
what is 600hp at the wheels is it about 440rwkw? please confirm.... cheers....
  • Nope 4
Sunshine coast. I'll take some and post them up tomorrow, about to go out. Also have sony stereo with dvd player/screen inside. Shocks and springs not coilovers as when i got those theyre were no good street compromise coilovers out like all the BC ones you see these days. Yes, its just a tad over 450rwkw.
  • 4 weeks later...
i have a gtr33 done 110,000 KM on engine....
no issues with engine at all....
doing 265KW at the moment and stocked turbo and engine with Power FC and adjustable cam's....
let me know if you are interested.....
Apparently just asks for power figures and what planet everyone is from :rolleyes:
On topic, saw this car on SCC, personally i dont usually like the S1's but i found myself staring at this quite alot on the day :P very nice car
Gl with sale mate
Expensive schools can produce expensive wankers. Not enough use of the little red minus buttons. It's a feature. Use it! Having just contributed to the problem, surely to god this thread needs cleaning up and setting straight again. A bloke is trying to sell a car.
Agreed, and what a car. One of the most comprehensively modded gtst's to grace this forum.
Can a mod clean this up and let the man do his bus.
  • Nope 1
Absolutely insane R33. Wish I had the money for it now man buy it in a heartbeat. Has to be one of the best S1 R33s I have seen.
And macdoodle69 get a life. This guy is trying to sell his car without you putting up your half page rants of dribble.
Doodle STFU. Any more posts in this thread from you will see you banned. PHT33, if you want to deal with this muppet PM him directly, I'd recommend against it personally.
Thread split to wasteland for teh lulz:
http://www.skylinesaustralia.com/forums/topic/350106-the-doogle-files/
Shan
Planet Earth
Will give you a pm about the car when i can next get some time free and make it up that way to come and have a look :cool: .... if you dont hear from me good luck with the sale, sure looks like an awesome ride for the price...
Edited by funkymonkey
Mate, this guys has taken over $1000 dollars for two forum member in december and still no word.
What has the world come to, be warned
PHT33 - You are about to be banned if you do not start sorting out the people you have ripped off.
SAU will co-operate with ANY Police/Count involvement/requests. We have plenty of your details so it won't be hard to track all of this down should it come to that.
Admin
Guest
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
