  • Replies 75
UM let me guess.......................STOCK AS A ROCK!!!!!!!
If you had mods and posted 153rwkw from a car that has 190 odd flywheel kw factory spec, wouldn't you be :Oops:
Thats my guess!
That's a pretty good power output then when you can consider the following:
* Full 3" Turbo Exhaust = 10-15rwkw
* Ex Cam Gear = 10-15rwkw
* FMIC = 10-15rwkw
Their's a potential 30-50rwkw just from another $3,000.
I got 160.6rwkw from AVO with known mods pod, clutch.. though a/m boost guage was showing ~10psi top end but still using the factory solenoid so there might be more mods than that (as factory solenoid is supposedly to be 5->7)
Exhaust looks stock as far as I can tell too.
dyno graph
dyno graph
wow 160 for those mods
very nice
was this on the race pace dyno mupkant? i got 153rwkw as well with safc pod boost but i have an exhaust, mine should probably have more power but i dont mind because im getting cool suspension soon and should be able to turn a lot better :)
i have no idea, but originaly they dynoed it with only boost and it was about 142rwkw, then with the tuned safc, they said i got an extra 10 or more rwkw.
Not to mention it was dynoed on friday which was 36 degrees day.
dyno graph
ive heard plenty about the AVO dyno readings...
Inark, it was on an official WRX club dyno day and everyone else who had their cars dyno'd - majority WRX though, didn't seem to be concerned about the figures (people who have dyno'd else where too).
So since it wasn't just me by myself there'd be no need for them to try and boost the readings.
From what I've heard AVO is supposedly as accurate as Docklands STI's one too.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
