would u be concerned if it was higher than ur last? :)
there have been a couple of people from this forum who have dynoed there cars on other dynos like BMT and the ones the guys from ICE use and then without any changes had them dynoed on the AVO pulleys with about a 10kw+ difference...
nothing major...
  • Replies 75
hahahaha dont listen to them mupkant, buy a killer handling setup and kick some ass when you get to round-a-bouts and other such turns (of course, ones that are on your own private test tracks, you know....)
i have nightmares about roundabouts, while back ago
sorta speed through a round a bout during wet road...and
lets just say i got really close to saying hello to the 'keep left' sign.
I aint implying anything. Its just that they use a dyno around the corner from their place if they are only running 1 car, so they dont have to drive all the way to bayswater and back and waste half a day. Plus with those minimal mods u can get false readings unless u go to joe blogs backyard dyno and reel off 200rwkw after the secret mods joe blogs has done on your car ;)
hehe lol
why did you have to crush my hopes of my car giving good performance ;)
maybe a 1/4 time should really show its real power?
oh btw its 95 model, so im suppose to have that freak ecu? heh.
The purple graph seems to be running preety straight 12 a/f ratio which took abit of tuning on my power fc to get on my tune. The stock ecu would be down in the 10 amd 9 a/f ratio on boost.
Your car was dynoed at the place around the corner from ice, MK as the dyno graph shows. It apparently has the same dyno as racepace.
Those numbers seem pretty right, i got a peak of 178rwkw at Race Pace, running at least 12psi, before dropping off to 10psi. I only had SAFC, exhaust, standard air-box and bleed.
I personally witnessed it.
Though, i beleive all dynos have a descrepancy, could be minimal, but most do.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
