  • Replies 75
  • 4 weeks later...
21-02-2004, 02:45 AM #32
fooey
Registered User
Location: Melbourne I got 160.6rwkw from AVO with known mods pod, clutch.. though a/m boost guage was showing ~10psi top end but still using the factory solenoid so there might be more mods than that (as factory solenoid is supposedly to be 5->7)
Exhaust looks stock as far as I can tell too.
dyno graph
man i knew that thing had a set of balls when i had it
160rwks is unreal for a stockish car
worst ever cent of 23,000 when i baught it back in da days
Shit man i cant make it on saturday, realli wanted to go but i gotta go to skool and i also have my Cars Timing Belt change. SHIT!!!! U know how much u got @ wheelz :)? cuz i like to know with a dyno chart of course :D dont trust peoples say :D
i have a 1996 gts-t with
3" cat back(and a 2.5" muffler in it to get past a defect)
jamex in box filter.
otherwise stock
and i got 165rwkw shootout mode about 26 degrees ambient temp.
that was apparently a pretty good figure :D
at unigroup in sydney btw.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
