Hi everyone,
My mate has an r32 gtst (auto) and its been playing up recently I was wondering if someone might know the problem.
Symptoms:
Irrattic Idle will be anywhere between 1600 and 400 it also stalls sometimes
The computer seems to be in limp mode when driving can't rev past 2500-3000, however you can free rev the car to redline no problems and sometimes
in 1st it will allow you to rev over 3000rpm its weird.
I checked the error codes on the computer and it did come up with 12 (MAF) but this could be because at one stage the car was running and I unplugged the AFM.
After it gave the error code of 12 I tried turning the car off (from on not started) again and then on to check the codes one more time and got 55 (no error) so we tried to
swap the afm over from my 32gtr but it seems to be a smaller diameter not sure why but yeah I'm assuming the reading would be different because of the size. So that
didn't really work
Maybe could I borrow someones AFM if they have time to check that is definetly not the problem.
Thanks in advance
Andrew.
https://www.sau.com.au/forums/topic/346639-rb20det-problems/
Hmmm so might be the o2 sensor ey, might be worth a look :) thanks for the advise.
The car should idle and run even with a stuffed o2 sensor. I drove mine for a week with the o2 sensor unplugged and the only difference I noticed was a slight increase in fuel consumption.
Yeah I have just been reading a thread about the o2 sensors so maybe I'll unplug it and see if anything different happens just to check. This is really annoying me and because its not my car I dont wanna go spending hundreds replaceing afms and o2 sensors if they are not the problems
The problem you describe sounds 100% like afm. I can replicate this problem by disconnecting the afm. I highly doubt it's the o2 sensor, you'll find your car should run fine without it albeit higher fuel consumption. You'll eventually get the check engine light 2 to 10 minutes after the car is started when the o2 is disconnected.
Edited by lukebaldan
Then reset the ECU and see what error codes come up.
Could be a sticking AAC valve causing the idle hunting.
  • Like 1
Yeah I might give that a go tonight, reset the ecu then check for error codes again :-) Hopefully I get 12 again. If this is the case is there anyone who can come around and let me swap there one in to confirm that, that is the problem? I guess it would have to be from a gtst because the one from my gtr is a smaller diameter afm so i'm guessing it would send the wrong signals to the ecu.
Update: so I disconnected the battery to reset the ecu over night ... re-connected and tried to start the car all it does is crank over, doesn't even fire up :S so now I have nfi. If it was the AFM that was on the blink the car should still start right?
Another Update: Well seems that if i spray carbie cleaner into the throttle body the car will fire up on the fumes, which lead me to believe it was the fuel system. I found where it plugs into the fuel pressure reg and unplugged it before that, when i am cranking the car there is no fuel coming out of the lines. So either the fuel filter is blocked or the fuel pump is knackered. :( I think I might be getting somewhere now tho :)
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
