Hey guys. This only started recently.
If i switch ignition on, but dont start the car, and then turn the key to off, even remove it, the igniton lights stay on.
I have to then start the car, and then switch it off for it to behave normally.
Because i dont usually switch the ignition on without starting the car, i'm not that fussed. but I thought if some knows what it is...possibly a suspect relay or something easy, I could sort it out.
Cheers :)
Edited by Munkyb0y
mongoose m80
oh and it's probably important to mention. the first time this happened was when my battery went totally flat, and i couldnt crank the car over, i was just getting that click click. i turned the key to off position to go grab jumper leads, and the ignition lights stayed on. had never seen it before then.
it has a new battery now, and cranking perfectly.
Edited by Munkyb0y
thanks for your help over the phone leon.
i checked out all the relays and found the problem.
it was a previous modification, whereby the aircon relay is connected to the rad fan relay via a one way diode, which switches the thermo fan on everytime aircon is on. THREAD HERE
when i put it back to stock, the igniton behaved normally.
why is that happening? possibly the diode i used? (1N5404 which is 400V 3A)
what's another way to wire up that fan so it comes on with aircon? coz i can certainly notice an improvement in aircon with it wired up.
cheers
Edited by Munkyb0y
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
