  • 3 weeks later...
  • 1 year later...
  • 1 month later...
I was going to do the Oil today. But the 370GT RWD needs a hoist. The sump plug is dead set in the middle of the sump. So it needs to be raised level otherwise it's not all going to come out.. DAMN!! Got the oil and filter ready to soon.
  • Like 1
  • 1 month later...
Running engine flush around the block isn't good!!!
Ask other people you will see.
Only suggested in idle!!!
  • 10 months later...
To help fellow owners of the JDM 2001-2003 Nissan Skyline V35 250GT Sedan's. These parts should be interchangeable for the coupes and higher makes of the V35 series. I was surprised that some of these parts are interchangeable with the current R35 GTR e.g. fuel lock lid actuator, tensioners, etc. I have completely DIY the following (complete with part numbers and prices that I paid in $AUD from Nissan Japan - get the parts of Amayama). To perform the timing chain replacement and all the jazz in between, you are not required to drop or remove the engine. Remove the front-end objects such as: radiator, hoses, clutch fan, air-intake, intake manifold etc.
  • Oil Filter (Nissan Pitworks)
    • AY100-NS004, $11.49
  • Cabin Filter (Denso)
    • 01453-50930, $26.16
  • Spark Plug - Set of 6 (Nissan NGK)
    • 22401-AL815, $86.76
  • Timing Chain Tensioner - Left/Passenger Side (Nissan)
    • 13070-EY00A, $30.67
  • Timing Chain Tensioner - Right/Driver's Side (Nissan)
    • 13070-JK21C, $30.71
    • 13070-JK21B, $30.61
  • ​Cam Timing Chain Guide/Slipper (Nissan)
    • 13085-JK20A, $12.00
  • ​Timing Chain Guide - Slack Side (Nissan)
    • 13091-JK20A, $28.94
  • ​Timing Chain Guide - Tension Side (Nissan)
    • 13085-AL511, $5.97
  • Main/Front Timing Chain (Nissan)
    • 13028-JK00A, $93.28
  • Cam/Camshaft Timing Chain - Set of 2 (Nissan)
    • 13028-JK20B, $74.46
  • ​Water Pump Set - Includes 2x Coolant/Water & Oil Seals (O-Rings) (Nissan)
    • B1010-AL50B, $68.60
  • ​Fuel Filter (Nissan)
    • 16400-2Y505, $68.11
  • Fuel Pump Outlet Seal - O-Ring (Nissan)
    • 17049-4M400, $3.32
I only just noticed this post now. I've never needed the hoist for it. I jack mine up from the usual lifting point where you would use the scissor jack for changing tyres. I have the urethane blocks to use with my trolley jacks to make this easier. Once I've jacked it up enough from both sides to get stands under there and unbolt the splash guard, I then pierce a hole in the oil filter to allow it to drain into the pan first. While that's happening, I lower the driver's side to keep the vehicle angled down towards the sump plug and then proceed with removing the sump plug and let it drain out.
Suffice it to say, the oil is still a dark honey colour after the first hundred kms, so I must be draining it of the old oil pretty well. A hoist would be nice to make things easier than crouching around in the driveway like I'm in a Jackie Chan film but it's good enough.
  • 2 years later...
I see the oil recommendation is a 5w/30, but have read elsewhere that in a warm climate like Australia, we would be better off using a 10w/40. That 5w/30 sounds ideal for a cold climate but here hardly ever see days under freezing.
I see a higher viscosity oil being less likely burned, or used+ less oil consumption, which seems like a problem with the VQ engines, although my Maxima hasn't had an issue with oil consumption in over 200000 km and I always used 10w/40 oil in it..
Any opinions?
Quoting from the gospel:
"SAE Viscosity Number ALS0006I
GASOLINE ENGINE OIL
SAE 5W-30 viscosity oil is preferred for all temperatures. SAE
10W-30 and 10W-40 viscosity oil may be used if the ambient
temperature is above -18°C(0°F)
I have used 5w-30 in both my VQ35DEs since I have owned them, I live in North Queensland, neither use any oil between changes.
My old J30 maxima specified 10W-30 oil, I used that until the day I got rid of it with 300,000km on it, it also used no oil between services.
Personally, I would stick with what the manufacturer recommends and only deviate from that if there is a good reason to. (eg, burning oil).  That said, 10W-30 or 10W-40 isn't going to hurt in a warm environment, possibly slightly higher fuel consumption though.
  • 2 years later...
    • I can also smell fuel in oil if that helps.
    • Hello, after engine rebuild(new cylinder liners and piston rings, arp headstuds, metal cometic tripple layer gasket, all new main/rod bearings) and roughly 100km made I did measure compression and it’s (1-6) - 80, 60, 90, 120, 110, 135. It’s rb25det series 1 - hydraulic lifters. Measured on cold engine. Didn’t check on hot due to overall car problems such as broken 3rd gear, idle issues, misfire etc. I did smoke test only on 2nd and 5th cylinder bcs soldering iron used with this method broke itself. So after setting cams to side - side 90 left/right angle I can see smoke coming off from intake manifold and turbo exhaust flange. 5th didn’t notice any smoke. Shop did head, valve etc job but I assemble it by myself. So I thinking about lifters. I don’t remember if they were soft or not it was long time ago. In my opinion I didn’t bleed them and they can be opened more than they should be. Can it be more likely possible? Or timing can be off by 1 teeth and can cause such weird compression? But if timing would be out wouldn’t it be like such big difference across all cylinders? Please help I’m so sad it happened.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
