Hey guys,
Couple of nights ago, i realised my driver side headlight was out, and as far as im aware, theyre not a cheap kit so i was pretty supprised.
So anyway, when i got to a set of traffic lights i played with the headlight switch a little, turned them off and on a few times and about the third time it came back on.
Now usually to start with it wont come on but eventually if i play with the switch long enough it will go on and it will stay on.
Ive been over all the connections to check for something loose but it all seems normal and doesnt seem to be the problem pinch.gif
Just want to know if anyone else has experienced this with their headlights before, and what the solution was?
https://www.sau.com.au/forums/topic/346676-temprimental-hids/
Ey Joe,
Has a similar problem once, one headlight wouldn't turn on, but turning them on and off would sometimes get it to come back on, then the other light did the same thing, ended up getting new globes, problem solved.
pull apart the headlight switch (attached to the indicator stalk), sounds like you might have some corroded contacts in it.
it's fairly common.
Yea my mate suggested that, but it wasnt, i moved the connections closer while i was there anyway.
But it turned out to be the ballast that has gone :(
I figured it was broken anyway and started digging at the silicone to try fix it. I soon realised it was NOT gonna work haha.
However, i filled it back up with silicone and put the plate back on and its now less temprimental but still not reliable.
New HID kit it is :(
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
