I was installing the SAFC 2 on my car this morning.
turned on the ignition, blue screen poped up, did the initial setting, tried to start the car, the engine turned but won't start.
The AFC2 is second hand, I re-set to the factory setting and tried all the function, but the car just won't start.
I checked all the wire connection, they seem alright. so I really don't know why.......
any idea?
any help will be much appreciated.
https://www.sau.com.au/forums/topic/346710-apexi-safc-2-problem/
by initial setting do you mean that you set the sensor type to Hotwire, Sensor No to 4 In and 4 Out, and Sensor Cal to 1 In and 1 Out. also the Car Select to 6 cylinder and the throttle arrow pointing up.
the other thing that come to mind is the two ground wires, did you get them around the right way i.e brown wire closest the ecu and black wire further back.
if you go into the etc. menu and go sensor check, does anything look out of the ordinary.
I checked with the wires already, it had been connected correctly according to the APEXI installation manual.
QWK32, yes I did all the initial setting like you said and after that the enigne won't start.
when I pulled the plug and re-connected the AFM signal wire back together like factory setting, car started and everything was back to normal.
so.................I still have no idea, is my AFC faulty?
but I can see the blue screen and all function seems alright.
Edited by STAGEA_KING
Yeah too easy mate, the settings aren't that hard to figure out. i just find that 9 times out of 10 SAFC issues are in the setup. I know you've said you checked the wiring, but something else it could be is if you have got the SAFC Air Flow Meter In and Out around the wrong way?
If that is right then as you said, you possibly have a busted unit. I don't know if it would be worth getting someone to check it out to confirm if it is dead or not.
Edited by QWK32
checked with all the wires and connection, everything seems fine.
It seems like there is no AF signal output from AFC.........
does anyone know how to test it?
You could measure the signal from your afm with a multimeter. Turn the safc to zero and it should output the same figure.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
