  On 10/12/2010 at 3:01 AM, joeyjoejoejuniorshabadoo said:
Has anyone really been far even as decided to use even go want to do look more like?
I'm lost ):
  On 10/12/2010 at 3:04 AM, LEANBAC said:
Hahahahhaha
My fitment is so sweet I can't even turn... I just go backwards an forwards
Still want it. :D (what the hell do you do with the car then? LOL)
https://www.sau.com.au/forums/topic/346720-my-toy/page/3/#findComment-5586253
  On 09/12/2010 at 2:32 AM, krzysiu said:
f**k you Kent. My Honda civic with a fully built buggati veyron engine running 4 t62r's turbos pushing out 4000hp:
Yea that's right!
Here's my time slip .1 seconds quarter on low boost (100psi) :
  On 09/12/2010 at 11:54 AM, krzysiu said:
Mate that's with my Vtec switched off. When I turn on the ol Vtec controller shit goes off tap! f**king extra 1000hp. So 5000hp at the wheels. Let's race boii!
https://www.sau.com.au/forums/topic/346720-my-toy/page/3/#findComment-5587171
  On 12/12/2010 at 9:24 AM, PM-R33 said:
The entire universe according to certain theories ;)
However if you follow M Theory and Superstring theories the universe was here all along prior to The Big Bang....
umm god created all..
duh.
https://www.sau.com.au/forums/topic/346720-my-toy/page/3/#findComment-5588558
20 inch advans!!!
Nice bonnet, did you source it locally?
Car looks the goods Peter, the boys at Chasers tell me you've been doing some laps at Winton. Would like to see what it does on semis...
Well done, the car has come a long way...
https://www.sau.com.au/forums/topic/346720-my-toy/page/3/#findComment-5597654
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
