ok mate
i looked at Mat's video on youtube and these are my questions.
So i hook the timing light up to the #1 cylinder ( start the car), and since my rb25det stock timing is 15 deg BTDC i would line the 15 deg mark on the crank pully up to the mark on the timing cover. If its not lined up when i start the car. i would need to adjust the triggering angle, until it lines up to the 15 deg mark. then this 15 deg would be locked in ignition lock. ( is this right.)??????????
What should the light read after setting it, when i rev the car.?????????????
https://www.sau.com.au/forums/topic/346732-haltech-ps2000-basic-ignition-setup/
You can set what ever timing lock value you want with the haltech's.
In ignition setup click Lock Timing and set it at 15 (if that's what you want to look for) or you can leave it at 10. If you leave it at 10 adjust your timing until you see the 10 degree mark line up and if you change it to 15 look for the 15 degree mark. Once you have set the timing unclick the Lock Timing box.
After you unlocked the timing box the timing will change when you rev it as it will be running of the ignition maps not just a locked timing value.
Edited by D_Stirls
