ok mate
i looked at Mat's video on youtube and these are my questions.
So i hook the timing light up to the #1 cylinder ( start the car), and since my rb25det stock timing is 15 deg BTDC i would line the 15 deg mark on the crank pully up to the mark on the timing cover. If its not lined up when i start the car. i would need to adjust the triggering angle, until it lines up to the 15 deg mark. then this 15 deg would be locked in ignition lock. ( is this right.)??????????
What should the light read after setting it, when i rev the car.?????????????
https://www.sau.com.au/forums/topic/346732-haltech-ps2000-basic-ignition-setup/
You can set what ever timing lock value you want with the haltech's.
In ignition setup click Lock Timing and set it at 15 (if that's what you want to look for) or you can leave it at 10. If you leave it at 10 adjust your timing until you see the 10 degree mark line up and if you change it to 15 look for the 15 degree mark. Once you have set the timing unclick the Lock Timing box.
After you unlocked the timing box the timing will change when you rev it as it will be running of the ignition maps not just a locked timing value.
Edited by D_Stirls
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
