hi selling my rb25 twin turbo engine as i dont have the time to finsh my car
it has been fully rebuilt chemically cleaned crack tested crank balance reassenbled with acl race series bearings and rings semi forged cp pistons cometic multi layer steel head gasket(1.3mm thick) head has had a mild port and polish it has a adjustable cam gear on the exhaust cam greddy style plenum with billet 80mm throttle body 800cc injectors on a billet fuel rail custom stainless turbo manifold 2 Gt35 ball bearing turbos(cost $1200 each) single 60mm wastegate all oil and water lines are braided rocker covers have been polished to a mirror shine dump pipes included i was gonna put this in my vl but i got 2 little kids that get all my attention now days it also comes with 044 fuel pump surge tank malpassi rising rate fuel reg this was built with big power in mind it is yet to be run it so it is completly fresh comes with rb25 loom any questions just pm me im after $6000ono im also open to swaps let me know what u got ill consider anything of equal value cheers
i also have a genuine vl turbo mx7 5 speed gearbox conversion in excellent condition including pedal box cluttch slave cylinder brand new exedy heavy duty button clutch everything to turn your auto into a manual could do a deal for both if interested also available with just the box and engine without conversion again could work out a deal
https://www.sau.com.au/forums/topic/346768-rb25-twin-turbo-engine/
  • 3 weeks later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
