Got to take my Cefiro out on the weekend and have a play with the factory turbo Laurel setup.
Alot different to R32 turbo's IMO.
Despite no BOV, close to zero flutter/surge in gear shifts (somehow)
Turbo starts singing at 2500rpm and is on 10 PSI just before 4000rpm, the sound is completely different.
Vids to come.
But for now, I taken pics of difference.
A31/C33 use a 16V - 10
R32s use a 16V 9
Everything else appears to be the same.
Different number on the wastegate actuators from memory. Exhaust side exactly the same, housings, wheels, etc all the same.
https://www.sau.com.au/forums/topic/346820-factory-a31c33-turbo-vs-r32-turbo/
was looking at my rpms/boost clearly yesterday and if i full throttle it hits 10psi at 4k(r33 s2 turbo)
you stated 16v9 is r32, i've got a spare 1993 rb20 turbo thats "16v" and no other markings on it
so 16v 10-9 might be a variant between the 1988-1992 a31/c33
ref pic( not mine just a pic off sau)
Edited by Dan_J
hmm - nah sorry guys i'm with nic on this one...
this would explain my cefiro DE+T setup how i was on full boost at like...
0.000001 of an RPM lol
Nic knows what i'm talking about... his whole face lit up. hahah
Nah this one isnt a DE+T. Factory turbo auto halfcut. Atleast I don't think it is. The KMS are mismatched to the dash, possible they blew the long motor and replaced it, keeping the C33 gear like turbo, pipework, etc. ..but doesn't feel same as Rowans. Rowans had lots of torque and spooled up even earlier and quicker (start 2000 - full before 3000)
Dan, what turbo do you currently have fitted?
The pic with 16V and no other markings seems to have same type of fins. (straight, closer together)
If the fins are different between the two you have, try both turbo's. I'll do the same.
The motor in the other Ceffy was running ok but the actuator was sometimes a bit of a joker. Trying to open up at idle, not opening up at all, jamming open, etc.
Edited by Nic_A31
also no can do bout the turbo swap on mine as its my daily, id only swap it if the current one was dead or if i upgrade/ get a newer + melbs summer rain + no car shed :/
Edited by Dan_J
Something definately up here.
Fixed my exhaust leak....it sounds less like a blower and more like a turbo and response is again even quicker.
Light accel it'll stay off boost whole way through, under mid to heavy load it'll start spooling at 2000-2200 and tonight it regularly saw 10PSI at 3000rpm.
Still kicks in a tad later than Rowan's old DE+T (although that did have other mods helping it out) but see's full boost around same revs. Still doesnt feel like DE+T torque curve either.
Vids to come.
(Was having a hard time trying to get boost gauge and tacho inside frame, and drive without crashing - gotta find a passenger :D )
Edited by Nic_A31
what intercooler are you wearing mister??? get an R34 SMIC :)
i didn't have THAT many mods... just turbo back / dodgy K&N filter
in case you're unaware - R34 SMIC goes straight up - no custom work! :)
(and it's a HUGE smic)
every stock 20 i ever owned spooled about 2krpm full boost by 3 , i only ever drove one that was about 500rpm later , but i suspected a tired motor (and years of 14psi all day every day) , personally , a rb20 ceff/r32 stock feels stronger than a equivalently stock rb25 r33 by seat of pants dyno
Weird how everyone has different experiences with turbo's .....
All stock at the moment for me. K+N pod filter with a decent amount of cold air, apart from that she's all stock, even the exhaust.
Keen to see how mine'll go with a 3" turbo back and a manual boost controller.
Last night it also peaked at 11-12 PSI a couple of times for some reason. Couldn't con it into doing it again...I think 3 times it hit 12 then slowly dropped to 10 almost straight away.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
