Hi guys and gals,
need some help with my line :) Lately, when I've been driving, I get a sharp squeeling sound when I brake. I would need to brake it hard, for the squeeling sound to stop. Anybody know whats wrong, and how it can be fixed? Maybe, use some grease or something? :Paranoid:
Thanks, any feedbacks would be sweet! :P
https://www.sau.com.au/forums/topic/34686-squeeeelz-when-i-brake/
You may find that your pads have not worn evenly (or you may have sanded them back) and when you apply light pressure the full face of the pad isn't touching the rotor so it squeels (this is what I was told by a reputable brake mechanic in sydney). I get a similar noise on very few occassions, if I softly press the pedal I get a gentle squeeze but if I stand on it then it brakes like it should and without squeel.
You may also want to take ur wheel off and make sure the little shims are in place.
on a similar note......sorry for the hijack....my mates 96 rex makes a loud clunk noise from the front passengers side when breakin all the time. this was after he had them changed and machined. i think they left something out when putting it back together. any suggestions on this??
Knowing absolutely nothing at all about cars, could it be his castor rod bushes that have worn out?
My mechanic replaced mine because they were wearing out and asked me if i had noticed a thunk noise when stopping.
If it makes that clunk noise after you have just finished turning a series of corners it could be worn/wearing wheel bearings causing the caliper/rotor to move and then when you apply brake pressure it has to push everything back into place.
Where can you get some wheel bearings for a R33?
I get some small clunking when I'm turning and braking at slow speeds, I was thinking it was my caster bushes, it clunks abit when you are going straight and over a few bumps as well.
My brakes don't squeal when I'm going forward but they squeal like a b!tch when I'm going backwards.:Oops:
yeah he did mention that when he turned left the car feels strange like theres some reisitance. ill pass the info on. cheers guys.
RB74's are bendix ultimates rite?? mine dont squeel at all under normal breakin, only under really light breakin and of course reverse...hehe
RB74's are NOT Bendix and they are NOT DBA pads they are www.racebrakes.com.au pads. Bendix pads are designed for the daily driven Falcadores where as the RB74's are designed for the performance/track cars.
I put on a new set of Ultimates on mine a few weeks ago, and followed the 'bedding instructions' as per this site somewhere. I also have new wheel bearings.
They squeel under light braking, my old pads never squeeled.
The only difference I noticed between the new and old pads was that the ultimates only had metallic 'wings' on 2 of the 4 pads at the bottom, anyone know what these 'wings' are?
My stock pads & ultimates looked both the same. 2 of the 4 pads only had metal wings. As do the Maxi-stops I am currently running.
Did you remember to remove the shims from the origional pads & put them on the new?
Its easy to miss especially when the old pads are covered in lots of pad dust.
My ultimates never squeeked. The new el' cheapo Maxi-Stops ($26 an axle) don't feel anywhere near as nice, produce 1/8th the dust & squeel slightly after being pushed hard.
My pads didn't squeal until I had rear camber adjusters put in and the mechanic got the grease on the rear right brake disc. The front right brake now squeals. I think it got overheated having to cope with more braking as a result, probably just need right front machined again.
When I very very lightly touch the brakes the squeal is intermittent as the wheel turns it is only in one spot. Uneven disc? Perhaps carbonite build up? Can you see carbonite build up?
Would it be advisable to try putting some grease into the shims first or go straight for disc machining?
Would the grease on rear right disc wear off or will I need to use some brake cleaner or something to make sure it doesn't come back?
RB74's are very abrasive. 5 times as much I am told to Galver 1105's which stop real well, much better than ultimates.
Utimates are very very dirty and sqeal like a freight train, went deaf for a day due to the noise after 5 hours of driving, and to keep your wheels clean with Ultimates requires washing every day instead of once a week.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
