Hi Guys
Ive got a HKS GT3037 ProS turbo and R34 GTR Nismo style carbon bonnet for sale. Brought them more then 1 year ago and never had chance to put it on my car. Sold my car 6 months ago just remember that i had them in my garage doing nothing, so might as well sell them and buy something nice for christmas :)
Brought the bonnet brand new from Josh @ JSAI more than 1 year ago and its been sitting in my garage ever since.
Turbo was brought around the same time. I had been told it done around 4k and can be fit to my RB25. I know nothing about turbo,all i know its this will make my car 250KW at the wheels and its a genuine HKS. Any inspection is welcome.
Im after $1800 for the turbo and $950 for the bonnet. Offer are welcome but please no low baller :)
Im not on this site often so msg me on 0433448985 or email: [email protected]
Item are in DEE WHY,Sydney. If you are from interstate please get yourself a quote for shipping.
Hi,
Is the 3037 proS Internal gate and does it come with all bits included in the kit or just the turbo itself?
Cheers
Hi,
Cheers
Sorry man..Ive got no idea as i dont know what the kit comes with..uploading the photo now so check it out yourself..
um i live in victoria.
do u have the packaging it came in (as in a cardboard box not just bubble wrap.
r u willing to ship ?
cheesr
julz
Can you get them to pick up?? My post code is 2099. I can get some cardboard boxes and bubble wrap to wrap it, I dont have the original box.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
