Hi guys just trowing this it out there to see if anybody is interested:) so where do i start here is the list of the mods down to the car smile.gif brought car for my partner a while ago as a gift, its just a little to big for her and she dont like how the auto box changes into gears cause of the bigger belts in the gearbox very very snappy smile.gif i love it. but its her car. throw some prices at me i have 13 grand o.n.o
Features of the car:
* Air conditioning
* Power windows
* Folding rear seats
* Reclinable rear seats
* Power mirrors
* Cruise control
* Power steering
* Rear window wiper
* Shockers on the bonnet to hold it up
* ABS
* Driver and passenger airbags
* Rear cargo area 12V socket
* Hooks built into the rear cargo area floor pan, for use with tie-downs
* Cup holders front and rear
* Climate control
* Currently 162,000kms (service just done top oil and filter only used)
Aftermarket modifications
Engine/Driveline:
* GCG highflow turbo (Cost $1950 + installation) running 10psi and 17 on high.
* Aftermarket exhaust from "Exhaust Technologies" in Adelaide (Was $1580 custom made)
* Highflow catalytic converter from www.bosimporting.com.au (Cost $440)
* Bosch 040 in-tank fuel pump (Cost $280 + installation)
* TRUST V-SPL GTR FMIC and custom made stainless steel piping, NO HOLES CUT for pipes in chassis! (Cost $450 for the intercooler, $600 for the piping, plus installation)
* Splitfire coilpacks (Cost $800)
* Apexi AFC Neo (Cost $600 + installation)
* Apexi SITC (Cost $250 + installation)
* Timing belt changed with 75,000km on the clock. Idler pullies/belt tensioners checked and found OK
* Upgraded automatic gearbox with an MV automatics valve body upgrade. (Cost $480 + installation)
* Larger Davies Craig transmission fluid cooler (Cost $150 + installation)
Brakes:
* Had the front and rear calipers checked, cleaned and rebuilt. At the same time installed DBA 4000 series rotors on the front, new Nissan rotors on the rear, new Nissan handbrake pads, New Bendix Ultimate pads on the front and Bendix pads on the rear. (From memory, was about $1500 total at the time)
Handling:
* FULL Bilstein/Whiteline suspension kit bought from http://www.skylinesaustralia.com/forums/in...showtopic=85592 including shocks/springs/castor bushes/camber bushes/subframe alignment kit/new bump stops/new dust covers (Cost ~$2250 + installation of bushes + wheel alignment)
* R33 GTST front strut brace, painted in black (Cost $80)
Body:
* Series 2 stagea front end update (Cost on the update was $14,500 including parts, painting, fitting, electrical changes, everything). Work performed by Luci and his crew at Melbourne F1 Panels in Fawkner.
* Blitz Bodykits fibreglass vented bonnet (cost $1800)
* R34 GTT wheels
Other:
* 2000kg capacity (Yes, TWO TONNE) tow bar from Towbars of Wooden in the ACT (Cost $560 + installation)
* Nesa DVD Headunit, Factory Nissan/Clarion in dash TV, Hertz HSK165 front splits, Hertz HCX165 rear 2-way speakers, Audison SRx 4 channel amplifier (Cost $1500 + installation)
* Cyclops 2 point immobilizer, black wired, Australian insurance compliant, installed at Performance Car Audio in Bayswater Melbourne (Cost $450 installed)
* Aftermarket cruise control (VERY VERY handy in Australia. Cost $500 + installation
WILL post up pics tommorrow after i wash it smile.gif a little bit dirty in the pics i have thanks for looking
This post has been edited by sik513: Today, 05:23 PM
Attached thumbnail(s) img-resized.png Reduced 89% post-201907-1291789386992168140_thumb.jpg
https://www.sau.com.au/forums/topic/346915-nissan-stagea-1997-series-2/
  • 1 month later...
  • 1 month later...
sorry guys i have no internet at the minute:( i can send you photos via sms if you would like. my number is 0458606383. price drop down to 12000 considor swaps for s13 s14 r32 180sx thanks guys
this used to be alexcims old stagea (most of the work was done by him)
title is a little misleading, you can't just call it a 97 series 2 - series 2 denotes many more changes beyond a simple facelift, which haven't been done to this car.
never-the-less, good luck with the sale. stageas are an awesome car
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
