PICS COMING SOON...
I've got lots of r32 GTST parts that are taking up space and need to go.
Located in Canberra - will post at buyers expense.
Or... I am moving to Melbourne in January, and you can organise to pick them up from me there.
r32 boot - rear wing properly removed and sealed up, so no holes - is silver but could do with a respray - $50
r32 gtst rear bar - silver - great condition - $40
r32 power window motor - passenger side - works perfectly - $40
r32 tail light - passenger side - silver - great condition - $30
r32 gtst front hubs including rotors and brake calipers - $50 each or $80 for the pair
r32 gtst suspension - king springs (+ KYB shocks on the rear two, stock shocks on the front two) - $100
Aftermarket steering wheel - 'Drift' brand - never been used - $40
R32 - R34GTT conversion kit
Everything you need to convert the front of your r32 to a R34 GTT.
Fibreglass front guards
r34 Fibreglass vented bonnet - 'stage 21' brand
Stock r34 Front Bar
non-xennon r34 headlights
Not sure how much this is worth. I paid a small fortune for it, and its never been used. Would prefer to sell as a whole, but will part out if nobody wants the whole kit.
Make me an offer $
R33 parts
r33 gtst brake calipers - $80 front two *** $60 rear two *** $110 all four
r33 gtst brake rotors - $30 front two *** $30 rear two *** $50 all four
As stated above...
Located in Canberra
Will post at buyers expense
Or I am moving to Melbourne in January and could take the parts with me if required.
Post here or PM me / sms or call me on 0422 725 457
Thanks
https://www.sau.com.au/forums/topic/346924-r32-gtst-parts/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
