So im sick of the lack of light my headlights give out, its just pathetic.
But im not sure what to do in relation to this. Here are my 3 options as i see it.
1. Buy HIDs (H4's if im not mistaken), replace low beam, hope i align them right and be happy
2. Buy replacement globes of a higher power
3. Buy HIDs that are replacements for both hi and lo beam and once again hope i align them right
any option ive missed?
any input would be much appreciated :)
Nick
https://www.sau.com.au/forums/topic/346947-headlight-advice/
I would personally go with option 1.
You most likely wont need to use your high beam once you have upgraded to HID because they are bright enough. i have 6000k HID and they are great no trouble with glare and they produce a great amount of light a lot better than standard or upgraded halogen globes. I tried upgrading my globes to Phillips Crystal Vision but they sucked just as much as the factory supplied globes so i tried HIDs and ill never go back to normal halogen globes again.
I have honestly used my high beams only on two or three occasions its really not worth spending the extra $200 for a set of high beam HIDs when you wont be using your high beam.
I would stay clear of those cheap kits and get some decent ones (Phillips, Morimoto etc...) you only change your lights every 10 years or whatever so may as well pick something decent but its up to you, most HID kits have a slightly different light and colour output, for example a 6000k HID kit might look slightly different side by side with two different brands. have a look at http://www.theretrofitsource.com for decent brands i bought my Vega Diamond kit from NYTSKY.
Edited by DarkRyda
I looked into doing this but found enough info on Gogle to put me off. There is a reason why these conversions are illegal in most countries and that is that the headlamps are not designed for them and so although they are very bright to look at a lot of light is scattered so as to dazzle oncoming traffic. If you have a car that had them originally but had them ripped out by compliance people then it would be OK to restore them but otherwise not unless you fit a suitable complete headlamp.
yeah thats why im a little worried...
I thought all stageas came with XENON headlights out of the factory...making it ok for stageas to get a HID conversion if compliance have replaced them with halogens...??
yep, i am glad everyone arrive to their own conclusions because HID kits in halogen bowl headlights is not cool. i had it in my lexus and the glare used to hit the road signs on overpasses from 100m away, the glare was so bad.
only option is to buy a set of Xenon S2 lamps and whack those in, although the cutoff isn't that great in mine IMHO.
or you buy a set of non-xenon lights and to a HID projector retrofit which would be awesomely cool.
see www.theretrofitsource.com for parts.
you'll need to be pretty handy though!
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
