Ultimate L Series
Im building one in the next few weeks for a customer
I have already finished the head
It showed up as 308 hp on paul gilberts flow bench, with 85 % exhaust flow
It has itb,s on it with a turbo and an hks scavenge tank
We are just using the std cam at this point but will look at some thing else later
It has haltech going on with 550cc injectors we are looking for 350 at the wheels
What's the big deal about Horsepower?
If you're doing a big bore L28, your going to need an N42 block and be sure to have it Sonic tested to be sure the bores are thick enough after the 3.0mm over bore. The common thought is to use the siamesed F54 block, but I will be very surprised to see any F54 block capable of taking an 89.0mm bore and the N42 block has a higher silicone content.
This L31 engine has been done to bits and very well documented online, but turbo is not normally the way to go, because the bore becomes a bit thin and under high boost pressure, the bores are porous.
I'm doing an 87.0mm bore (2818cc) 380 injectors, about 250HP @ wheels and over 600Nm torque, so who needs HP.
Your going to need; LD28 diesel crank, L24E rods, KA24E pistons for your bottom end. Rods should be chromoly or H beam forged & pistons forged to KA24E specs.
Cheers, D
Cheers, D
A'MEN
........OR
buy an OS Giken 3.1L and fuel inject it and turbOOOOOOOOOOOOOOOO it :)
would i be better off resleeving an l28 and adding an ld28 crank and suitable rods/pistons? least then il no how much meat ive got left in the bores?
also what head would u reccommend?
thanks for the replies appreciate the advice
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
