I have a brand new sump adaptor to suit converting a Rb30 to AWD.
Exact copy of the proengines one
Comes with all bolts, cutting templete and detailed fitting instructions
The proengine one sells for $750 plus freight
Sell for $525 plus freight $30
Pick up in Brisbane
https://www.sau.com.au/forums/topic/346966-sump-adaptor-for-rb30-to-awd-sump/
I'll give you $200 for it, surely I get a discount given you are using my business name to try and sell it?
I can tell you right now that although it might work it is definitely not exactly the same as mine, I can see a couple of spots that are a different shape just looking at the picture.
I've got no problem with anyone else making and selling these things, I do have a problem with some dickhead using my name to do it.
Cheers,
Greg
Cheers,
Greg
OK I will respond and let the Mods decide whether they delete this or not. They can delete the proengines reference if needed.
Firstly
1. I did not make or copy this, I bought it from a guy in SA that made one for himself and made a couple of extra's
2. I am not making any money from this, have decide not to go rb30 as it does not suit me and I no longer need this.
3. I was advised when buying it it was the same as the "proengines" design. From your response it is not exactly same, so I was miss lead. Sorry for the comparison.
4. Lastly, I am not a Dickhead as put in your words. I have been around here long enough to have gain respect from other forum users. I expect the same from you
    • yeah, there's a country that recently started importing Skylines, I blame them.
