Anyone have any ideas why my car misfires at two times:
1) cruising from 70-100 or so, then throw it back to 3rd, and floor it, i get a pause, about 3 small pops, and it takes off like a rocket. This is not so bad, just a bit annoying.
2) Taking a slow corner, or almost stop at lights or something, 2nd gear, low revs, if i give it too much too soon, i get almost full boost, but the revs wont pick up, it feels as if its choking, sometimes it misfires. I have to back off, let the pressure blow of, pick up the revs a bit, then floor it.
I have a SAFC, i dont think its fuel. The car has done this for as long as ive had it, im just getting sick of it.
Someone suggested spark, and pulling the plugs out, cleaning and gapping to 0.8 has made it a bit better. I have NGK plugs, any suggestions, new plugs (what brand), or other causes?
https://www.sau.com.au/forums/topic/3470-misfiring/
It sounds like not enuf spark is getting through for one reason or another. Could be coil packs playing up, heres a cleaning technique I read in HPI (or was it Zoom?):
- clean the rubber boot on the coil pack with degreaser. Dirt and grime makes it easier for spark to find ground through the insulating boot rather than the spark plug
- spray the rubber boot with a silicon based spray to further insalate it. (I used WD40)
If none of the coil packs are terminaly fautly, hopefully that should sort it out.
NGK plugs are safest to use with our cars, they come factory standard on all jap cars I've seen. Whats the service interval for NGK coppers, 10-20k km? Probably best to replace them if you don't know when they were last changed.
https://www.sau.com.au/forums/topic/3470-misfiring/#findComment-58078
yep, they are about 6000 k's old. There was some oil around the coil packs, which looked like it was clean, and put there intentionally, ill try WD40 or something. The coil packs actually look quite new.
I am going to get those expensive plugs, to see if it makes a difference, seings its only under high load, that it misses.
https://www.sau.com.au/forums/topic/3470-misfiring/#findComment-58152
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
