Well I have been modifying turbo cars for about six years and I have always wanted a GTR. My s15 puts out around 250rwkw at the moment but it's time for a change and something that's a little torquer off boost.
Ive always loved 32 GTR's and I have read as many threads as I could on them and RB associated oil problems (including sydney kids) 40 page boonanza.
I don't have a track to take my car too, I am past being 17 years old with a turbo car since I am now 24 and recently watched Steven Hawking prove that time travel into the past was impossible I know that's not going to relive itself.
I just want a 300kwish clean 32GTR that every now and again I can give it some stick and rip an occasional skid... very occasional.
http://www.carsales.com.au/all-cars/private/details.aspx?R=9549222&__sid=12CCCABFB3A0&__Qpb=true&Cr=2&__Ns=pCar_PriceSort_Decimal|1||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201246%201247%201252%201282%204294963846%204294963593%20900&seot=1&__Nne=3&tsrc=allcarhome&__No=105&trecs=317&silo=1003
Have a look at this one, it's clean as a bean but the only associated problem with it to me is the fact it has none of the oil mods done to it. I'm not necessarily getting this car but something along the same lines.
Is there any particular things for the sort of car I want that I should make sure they have or any other input someone can provide.
Thankyou :)
https://www.sau.com.au/forums/topic/347035-purchasing-a-gtr32/
Not 100% sure but I have been told that the oil problem was fixed during 1992. Not sure if this is true either but the oil problem had something to do with the ceramic turbos. Can anyone confirm if thats right?
oil pump problem was rumoured to have been fixed the same time the r32 went to a pull clutch, oil stavation to bearings is still a problem in all models and is easy to fix simple run 1/2- 3/4 a litre overfull of oil and try not to turn corners at redline.
that is a very clean r32 and a nice colour pretty rare to, at that price it is well worth a closer look
Push / Pull type clutch, won't matter, the car will still function the same.
Nothing to worry about.
The oil pump drive would only tend to fail at high power modifications.
If your car is stock / lightly / mildly modified, you won't have a problem.
The one you see in the Car Sales ad, who ever modified the car would have been aware of this and would have kept it in mind and prevent any oil starvation from happening.
The car in the ad should not have any issues, but still ask the seller the question.
As all have said, run the R32's with more oil and you will be fine.
It looks neat, clean & the engine mods are quite reasonable.
Dark blue GT-R's are rare so that is in its favour. Check the paint code: Dark blue pearl (TH1)
Don't worry about the oiling issues in a road car.
You need to know this:
The modification involved a different drive arrangement for the oil pump on later model cars. Unless you launch the thing stupidly alot & unless the harmonic balancer is stuffed you shouldn't have an issue. I never did with an early GT-R I had.
As for oil volume. Motor takes 4.5 litres according to the manual. Just tip in the full five litre container & don't worry about it any more.
GT-R's are well engineered cars. As long as they are looked after & not abused they will do you right.
Golden rule: Buy a good one, not a cheap one.
gt-rs so would be pretty laggy i would imagine
worth a look though if that dont concern ya too much
Yeah twin GT-RS's are quite large, good for 800 odd HP. Not much noise before 4000-5000rpm.
Given that the engine hasn't been built yet, 100% make sure the comp is good.
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
