Hi guys I have a R33 93 and just wanted to know how much power I could get out of the shit I got???
Front mount
Bigger fuel pump... (044)
HKS FconS ecu
3" dump with wastgate pipe
3" exhaust to the cat then 3.5" after that
2850 stall converter for the auto
running 14psi
the ecu was tuned in japan on a R33 with the same mods and got 278.8 ps which is like 274.98 hp
I would like to get a better turbo if anyone has one or knows of any. would really like a stage 1 or 2 or even just a Hiflow one.
and also can anyone tell me how i can tell if mine is a S1 or a S2??
  • Nope 1
https://www.sau.com.au/forums/topic/347071-rb25det-power/
Guest
