I've searched the forum and now i just need to know if someone can confirm what it is needed to transplant a Series 2 engine i've bought, into a Series 1 R33 GTST.
The coilpacks and coilpack harness need to be changed to S1?
The TPS might be different but not necessary to change?
The CAS is different but should just hook up to the S1 connector?
What i've understood it might be possible to use the S2 coilpacks if the S2 coilpack harness is used but i dont know if its possible to just hook it up to the S1 main harness?
Help me out here guys :)
If your going to be using S1 coilpacks you need to hook the S1 harness up to an ignition module, if your using the S2 coilpacks, they have the ignition module built in from memory??
Anyway all I know is, S1 need ignition module and S2 doesn't :)
Thanks for the help, looks like im going to change the coils to S1 then, luckly ive got the old igniter pack laying around :)
Ill also be looking at a S1 CAS then, read somewhere that it needs to be modified to fit the S2 engine, but someone else said that the S2 CAS will work with the S1 harness :S
Reason why i havent bought the S2 harness and ECU is that i've got Nistune in the S1 ECU, used it for my RB31/26DETT build. Now that engine is sold but i've got a GT3076, SARD 800cc's and a Q45 AFM along with some more parts that im going use in this engine so ill be wanting to keep Nistune :)
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
