Hi all, i have been made project manager of my bosses r33 gts-t's upgrade and maintenance schedule. I am planning to change the 100km service items before embarking on a 380 kw rw upgrade quest. I am just wondering if anybody has had experience with genuine/ non genuine water pumps and what there experiences were. I am currently thinking about a protex N1 spec item but am unsure whether i should go non-genuine or nissan part. Any opinions would be appreciated.
https://www.sau.com.au/forums/topic/347088-which-water-pump-for-a-r33-gts-t/
i'm not familiar with the protex stuff, but my advice would be to stick with the genuine nissan pump. they are reliable and work well. the water pump only plays a small part in engine cooling. a bigger difference will be made by the quality of the radiator.
thanks, i am only considering non genuine as the N1 nissan pumps are $585 while the protex one is considerably less, i am on a budget to complete all the service items and attempt to get the performance mods also within budget. If there is minimal impact in pump performance going non-genuine i will go non-genuine and use the additional cash to buy a alloy cooling pro triple core radiator with the saved money
just jap have the N1 pump for $380. they also have the stock rb25 pump for $175. what sort of use is the car going to see? if it is going to be purely for track, etc then go the N1, if it is going to see regular street use then i would be going the stock rb25 pump. the N1 is designed for higher rpm use, so at lower rpm it doesn't flow as much (at least that is my understanding).
just take note that a lot of people have had issues with non-genuine pumps in the past and have ended up putting genuine pumps on afterwards. in fact a lot of people have had more success with rb30 pumps than non-genuine. if money is tight then definately go the genuine rb25 pump over a non-genuine N1 unit.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
