OK first of all I am not desperate, but have had my car for sale for a few weeks now and have had only a few calls (with no one turning up to inspect). The car is reasonably priced for what it is and is in perfect condition. I am just surprised how difficult it seems to sell R34s in the current market. I would love the cash right now but I am not desperate. Should I just be holding out till after Xmas? How are others finding the market at present for Skylines?
My add is here btw:
AD
mate theres nothing wrong with your car or your ad. everything there is fine.....Another guy i know with a bargain 2.3l evo is having the same trouble, look at the bigger picture, rates rose not that long ago, its right before xmas so everyone is tight anyway and most people go away for a holiday around this time, its not a sellers market atm. Your car will sell im sure of that you may just have to wait for the new year to come around.
That is a nice looking R34 you have there, and since this is a Skyline Forum I will expect some flaming but a couple of reasons it hasn't sold YET are;
1. It is Christmas time. Not many people buy cars for Christmas and I dare say the people that do aren't in the market for a turbo Skyline.
2. You are asking $20k for a 12 year old turbo charged car with 100,000kms on the clock.
3. The amount of mods on it will have one of two effects on potential buyers - a) love all the work that has been done and will be prepared to pay for it and/or b) be wary of all the work done on it and think it has had a hard life being thrashed everywhere
As I said before, really nice looking car mate... definitely one of the nicer 34 GTt's I have seen (to my taste anyway).
Good luck with the sale :)
Hiya Bryce,
Your advert is very well presented I think.
At my age, I would have just written "...mature aged gent..." but what you wrote isn't a mistake by any means.
If you have a Carsales advert that says St George area, it can imply ownership by a person of a certain race (simply by stereotype); so where your ad gives out your mobile no., I'd put in your Christian Name, and then that stereotype is destroyed.
Christmas time is difficult to sell, but January is traditionally harder. There's a ready market for cars in flood affected areas (due to many cars being destroyed), but I'm not so sure about performance cars being high on their list.
Cheers
Thanks for the wise words (and compliments) all.
It will be a shame to let the girl go, but I do need the money. <waits patiently till the new year and ads 12 months more rego>
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
