Mods
-Nur Spec Engine only done less then 20000kms
-Garret 2530-5 Turbo Kit (less then 3000Kms)
-Perfect fit turbo piping cost me $1500 for the perfect piping
-HKS Oil Cooler
-Tomei Dump Pipe
-Trust Front Pipe
-Fujitsubo Super Ti Exhaust with rainbow finished
-ARC Oil Catch
-ARC Air Intake
-Mines Radiator Plate
-Cusco Sway Bars Front & Rear
-HKS Hypermax II Supension Coilover
-Anti Hicas Lock bar
-Nismo 320Km odometer (Black)
-Nismo Upgrade MDF display
Suound System:
- Focal Front Speakers
- Clarion Amp
- Alpine Head Unit (DVD)
its my lovely GTR put soo much effort in to it from shipping to land to Australia and all the mod are carefully done!!! so im the first owner in Australia and own it for 4 years, i blow my enigine last year on track and change to a mint condiditon Nur Spec Engine only done 8000Kms when i brought it
the engine is brought from SAU member "togomatt" the guy has a beautiful GTR 34....
It's regretful to sell, coz im moving back to Hong Kong ><" was going to ship it back with me but the government tax for import is too high...Sign~~
For serious buyers only and must promise me to take care of it !!!
Just came back from oversea, therefore the Ad has been release on the web. urgently sale~~going back oversea soon...
Price can be nego~~~you cant find any better GTR34 then this one with such priced!!!
Price Reduced from $71000 to $68000
Alternativly with out the mods will let go for $60000, the price including the turbo and CPU, cant take them off.
Pictures are on carsales.com
http://www.carsales....seot=1&__N=1216 1282 4294963593 4294963846 4294933125&silo=1011
PM, SMS or Call me on 0434892592 for inspection Kevin"
Edited by kevinisagoodboy
https://www.sau.com.au/forums/topic/347160-gtr-34-v-spec-ii-pearl-white-4-sale/
The yellowish stain on the rear bar is probably due to the exhaust i believe. Happens to alot of white coloured sports cars with an exhaust.
I used to have a white skyline as well, after just 1 trackday, the rear bar near the exhaust area becomes yellow.
Not sure if this is the reason for the OP's car being yellow, but the bumper goes yellow from not running a cat. Nothing a bit of pre wax cleaner won't remove.
Any pics of engine bay. Rear bar colour is letting the car down..im still on the hunt for r34 gtr..
the rear is due to the heat of the exhaust...i can do repaint
u are right man......lol
will remove a bit but still can c the different
Happens to all 34's i think... Mine is silver and it is yellowing too. My mates white 34 is starting to do it too.
all the skylines i think lol....it's just too "hot"
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
