26 balancer bolt is 446 - 544NM
26 flywheel bolts are 142-152NM
25 balancer bolt is 142-152NM
33 manual doesnt have 25 flywheel bolts, i assume its the same as 26 tho. and 25 settings should be fine for the 30, especially if your using 25 bits for a 25/30
https://www.sau.com.au/forums/topic/347167-torque-setting/#findComment-5587317
are you using a 26 or 30 balancer? if its 26 just use the 26 torque settings, if its 30 use the 25 settings (from memory the 25 and 30 bolts are the same). i used all 25 specs (and 26 flywheel settings as i couldnt find 25) on my 25/30 and everything is working as it should.
https://www.sau.com.au/forums/topic/347167-torque-setting/#findComment-5588270
