B-Man do you know the specs of the turbo and its rated power from HKS? What engine internals have you had done?
Internals - Forged Arias pistons, Cryotempered everything else.
I think HKS rate the 3040 at 500 ps - I dunno how they do that when the exhaust housing options are 0.72 through to 1.12.......
  • Replies 58
think they actually go down to 0.61, as all the hks GT30s use the same turbine housing.
Love it B-Man, good power. Do/will you have power runs at lower boost pressures, say 14-17psi for daily driving etc?
The reason I ask is that I have a hybrid internal gate Garrett GT3040, which has a slightly different exhaust wheel to HKS as well as 0.60 A/R comp and 0.63 A/R exh, but otherwise sort-of close. I get 265rwkW at 17psi with all other engine bits totally stock.
Would be nice to know your power at LOWER boost as it might help me predict what might happen when I boost it to 20-22psi later with other bolt-on stuff optimised, like exh manifold, cams etc.
Don't want to push it just yet as I have stock pistons.
Also do you ahev stock cams? If so, 323 is awsesome.
Freebaggin: im no expert but I thought the garrent turbos were out of their effiency range at 20-22 PSI, I could be wrong, but I thought thats was where the difference was between your HKS and garrent turbos? Garrents make their power on lower boost and HKS make theirs up higher?
Sumo
Freebaggin - no sorry mate no low boost Dyno reading as yet.
Cams are 256/9 Tomei with Exhaust cam gear. A/F ratios not on this dyno sheet, but will get them on final tuned dyno graph.
Sewid - not back yet - had to go back for new clutch - too much power...... ;)
CHeers, ;)
Joel, if you go the smallest housing, you will most probably either spend alot of time going sideways in the traffic, or alot of time driving around with low boost
i totally agree there.
im going .82 on my gt3040 ... speak of the devil should arrive today.
Wicked Results though B-Man.
All your woes are finally turning into GOES for a change! :zap:
Sumo
Garretts run fine at high boost.
Thanks B-Man for info.
Laggy compared to a zed, YES.
Compared to a GTR not so much. We have over layed dyno graphs from GTR's we have recently done and one with N1 turbo's and Tomei cams etc was a little more responsive low in revs, but not much. B- Mans Skyline had more mid range and top end. With more to tune yet.
Single Trubo with higher comp than RB26.
As long as it comes on hard by 3500rpm i'm not worried what sized exhaust a/r it is.
.82 a/r should do it by 3500rpm on the 3ltr.
Nice results.
I just reeled off 256rwkw at 1 bar with a garrett 3040 with 0.82 rear housing and it makes power just likes yours bman. 3000-3500 around 7psi and then from just below 4000rpm 1 bar all the way to redline. I was just using a 1 bar spring in my external gate to control boost. I am hoping to run a few more psi also and see what she can do, but i still got stock internals.
As for garretts having a low psi efficience range, u should talk to the vl boys down at mel who are running over 2 bar with their garretts and running 9 sec passes, i think they will disagree with you.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
