INASNT,
The Garrets are good with high boost.
What every one is getting at is that the HKS turbo's are better.
Generally spooling a little earlier also.
Yep.. .82 a/r for me. :D
For the price difference from a new hks 3040 to a Garrett 3040 and the response/power difference garrett owners still come out on top i recon.
  • Replies 58
As long as it comes on hard by 3500rpm i'm not worried what sized exhaust a/r it is.
.82 a/r should do it by 3500rpm on the 3ltr.
EASILY. I think you'll be surprised just how early it comes on with a 3ltr.
and if you DET 3ltr, even more pleasantly surprised.
RB30et's (obviously they have a cam too) are coming in good at 3000rpm with plenty of response. And these guys are running the bigger GT35
Some even less (still with the GT35)... but that's all in the development of motor bits etc
INASNT,
You also have to factor in the price of external gates, manifolds etc.
The HKS3037ProS I am looking at is a T3 with internal gate. I can have one delivered to my door bran new for (last time I checked) $3100. Depending on exchange rate. + a 10mm spacer so the turbo clears the stock manifold.
Now we will get in to the discussion of how you think the stock exhaust manifold is so crap. :D If it turns out to hinder performance in a detrimental way I will go for a low mount manifold.
If it wasn't for the HKS having internal gate I would go a Garret.
I'm able to pick up a new Garret 3030 with a .82 a/r for $2200. + a good manifold ~$800-$1000 + wastegate ~$500-$800.
They work out pretty close to the same.
R31Nismoid,
Sounds good. I hope i'm not dissapointed with the RB30's response. :D
3030?? never heard of one. U wont get much of a manifold for $1000 as i found out after having to spend another $400 to make it half decent.
The fact is that at high hp and boost an internal gate cant bypass enough exhaust gas to stop boost spikes and keep low back pressure.
3030? Either have I.. I stated 3037.
INASNT,
you are correct that at high HP a standard internal gate won't pass enough exhaust gas to stop boost creep. Its got nothing to do with spikes & low back pressure. Its exactly the same as if you were to have an external gate that is too small. Boost would come up to the desired dialed in amount then as rev's raise boost will slowly start to creep over the dialed in amount then all of a sudden boost will increase very quickly and blow something.
HKS design their turbo's internal gate to be able to pass enough exhaust gas. The problem with a T3/4 is that if the wastegate isn't large enough you will get boost creep. Providing it is designed correctly internal gate is just as good as external. The problem is you are limited with the amount of room hence why HKS don't make turbo's with internal gate any larger than the 3037ProS.
INASNT,
Compares the wastegate openeing on any hks internal gated turbo to an external gate. There is no way he small internal gate openeing will come close to bpassing as much air as an external gate. I have seen a few dvd's with a hks guy showing the difference in the internal gate section of their turbos, and to tell you the truth the 3037 pro s doesent look like it has that greater area for bypass.
INANST,
HKS3037's in twin have made 700rwkw on a GTR in Japland.
Maybe I should word it like this.
The power a 3037ProS is going to make (rated at 480hp), the internal gate design will be sufficient.
RBS13,
My bad. Typo 3040.
We were on the general discussion of 3040's.
INANST,
RBS13,
My bad. Typo 3040.
:D
You may find this table interesting.
INASNT, I think you have to remeber that the more exhaust gas you run through the turbo, the less the wastegate needs to do.
top secret use 2 3037 pro S turbos to produce 700rwkw on an RB26 (or 27, 28?) cant remeber which, but the thing is, they do it with internal gated turbos
grepin has 280odd rwkw with an internal gated hks turbo, an only runs 1.3bar, but can turn the boost down further.
Its worth considering too, that if you can save 500rpm lag, you may pick up alot of RWKW. With my turbo, changing the exhaust brought boost on around 500-800rpm earlier, but I picked up an extra 60rwkw in power as a result - as it was coming onto boost, and around 12 or so up top. I will have to dig up a comparison to post up, I found it interesting anyway.
In total I picked up an extra 32 rwkw average from 100kph to around 160 kph (in 4th gear)- well worth having, when you consider how much those few extra kw cost once you start stretching the limits of the stock turbo,injectors etc. So if you pay an extra $500-$1000 dollars for a turbo that comes on boost 500rpm earlier, perhaps it is worhtwhile - I think so
Its a case of horses for courses I suppose, as long as everyone is happy with what they got, then they did it right, no?
yep fair enough!
I guess i went for external gate coz i saw a few other people going internal gate, then external gated turbo as it didnt perform as well as they hoped. I didint want to go down that path also hence y i went external gate straight away.
  • 3 weeks later...
Guest INASNT
Love your catch can B-man, im looking for one at the moment, where did you score it from? What was the final power figure...stick with the Microtech???
Oh and INASNT, is your car running??? What power?
I got 257kw@wheels at 1 bar (using only wastegate spring)
Getting dynoed again on tuesday with hks evc 3, special cat, new catch can and about 18psi to see what it pulls.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
