Hi i am looking for a passenger cefiro front caliper model I have is 92 needs to be theABS as I have tried the non abs and it's 20% or so smaller. Won't work. I'm located on Brisbane QLD happy to pick up
https://www.sau.com.au/forums/topic/347204-a31-cefiro-abs-front-caliper/
too hard to find man.... just get ABS s13 sr20det calipers and disk's used... also s13 brakes a slightly smaller so the non ABS one stated above could have been a s13
Edited by Dan_J
ok Dan, fair point.
Cefiro Non abs small. ABS Bigger
i mesaured the disk thickness 22mm thick "worn" and the outer diameter is 256mm. The Caliper is 180mm long measured in photo format below, if that helps with other matches.
What are R32 4 spot disk Size? same or are mine some where in between s13 - r32?
Regards
Edited by pikie new account
i posted a thread or post which i cant find now in the taxi section with info on the s13 sr20de brake vs non turbo ceffy brakes which were bigger although i dont have turbo brakes on my car so i cant tell how much better they are but r32 gtst brakes are better
here's some info:
http://www.sr20tuning.com/brakes.html
Edited by Dan_J
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
