G'day just in the pocess of rebuilding my rb 26 for my r32 gtr and wondering what sort of power to expect once its done and tuned. mods include
-bored to 86.5mm with forged cp pistons
-eagle rods
-2 Garret 2560 (-5) Turbos
-bosch indy blue 1600cc injectors
-billet fuel rail
-z32 air flow meters
-nizmo fuel pump
-nizmo fuel regulator
-different coil packs not sure though what they are
-os giken cam gears
-n1 oil pump
-3 and half inch exhaust
-blue printed and balanced crank
-standard cams
-acl race bearing
-computer is a apexi power fc with hand controller
all info will be much appreciated and what sort of boost would be expected thanks for everyones input.
https://www.sau.com.au/forums/topic/347206-rb26-build-what-power-to-expect/
Your injectors are way too big for a BP ultimate tune. Switch to 700's or 800's and you'll be able to get it to idle with a sane AFR... but 1600's! Unless your using E85 they are pointless.
And 350awkw would be achievable.
  • Like 1
Please read the 26 dyno results thread. there are plenty of results in there to view.
there is also a 15+ page thread on these turbos.
the norm is 380-400rwkw on pump
420-440rwkw on E85 others have said, those injectors are ridiculously big for PULP. 800cc are fine.
thanks.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
