Car was left outside today and i have just had an amp and new speakers and head unit installed. jumped in the car now and the speakers were making very loud siren sounds like a warning siren. The car was very hot.
The car Audio has been fine apart from this time, the only time the car was stinking hot. my fault.
Edited by sydking
https://www.sau.com.au/forums/topic/347207-loud-siren-sound-from-speakers/
Sydking
couple of Q's to clear thing up
What Brand/Model deck and amp have you got?
are all the speakers running off the amp. Or some on the amp, some on the deck (which ones scream)
Was the sound 'Like' a siren or an actual siren (some Decks have alarms in them)
Does it scream with the key on and the deck off?
does changing Volume or changing source(CD, Radio) have any effect
and did it come good/change after it cooled down?
If your confident get a multimeter and check the voltage on the amp (Batt and Remote)
I know its a bit of a list, but the more info the better.
So far I'd say given the heat, youve got a dried out Cap in the deck or amp but need more info B4 I send you back to the shop
cheers
Bundy
Edited by BundyBear
Cheers for the reply mate.
Deck is a Clarion CZ100a and the Amp is a Clarion APX 4241
Only running front splits, and yes they are running of the Amp
Turning the volume up and down does nothing to the siren sound,
The sound will stay on with the unit off, and for a second or two after i take the face off. (which is the only way ive been able to stop it)
Jump back in the car once it cooled down, did the same thing but i took the face off and put it back in. went back to normal.
Since the install after having to return a faulty head unit i added a Antenna cord to the back on the unit and got the antenna wired back up. ( done by the installer)
Edited by sydking
yea Sounds like the RCA outputs amp chip got hot and went into thermal runaway (basicly got to hot to work properly), this is NOT a PREMINENT condition, although could be indicative of a poor op-amp design
if its back to normal now, I wouldn't worry bout it, but a windscreen shade is probably a good idea
while car audio gear is made for 'harsh enviroments', it's not always made for an 'Aussie Harsh Enviroment'
Cheers
Bundy
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
