the car will run with out VCT will just be a bit doughy down low, if you want the GTR plenum then you will need the RB26 fuel rail and injectors to suit, if you use the GReddy plenum then either the standard RB25DE or RB26 rail will work but the topfeed RB26 injectors will need collars made up to fit.
You can modify the 25 injectors and use them
Why does every thread in the NA section have somebody repeat for the millionth time how NA's are not value for money and that a turbo will make far more power for less money. Everybody knows this and are really sick of reading about turbos in the NA section.
People post in the NA section for a reason. If your answer to every question is to turbo and not waste your money with NA's maybe you're in the wrong section.
Have a cry mate.
We say it BECAUSE Every thread in here is the same old story i.e Im on my P's I want to go fast but cant have a turbo
We are trying to help people not waste thousands of $$ for a handful of horsepower
It's been said too many times. Nobody cares. If your answer is turbo then really your help is not wanted.
"We are trying to help people not waste thousands of $$ for a handful of horsepower"
There are many reasons people would want to NA over turbo. Not everyone wants 600hp. NA's sound cool, they have old school appeal, they 'fit' better in certain cars, they can be easier to modify without being too obvious (sometimes). Those are just a few reasons.
Honestly why are you here anyway, you have 2 toyotas and believe turbos are the answer to every problem. Yet here you are as always patrolling the NA skyline section.
Yep I have two toyotas...so fkn what!
I love NA engines, but an NA RB in a R33 is just fkn stupid when there is a factory turbo option.....If you pull your head out of your ass and look up a few posts you will see I gave advice on what I would do if I was going to build an NA RB25..
SO STFU do some reading and you might learn something.
I did read that and yes you do often give some useful info, but not before you spin the same old turbo crap that this NA section is full of.
Please don't patronise me mate.
Give NA advice but leave the turbo crap in the turbo section.
For the record I have both a turbo and an NA.
sounds like you've been driving the NA too much :)
at the end of the day with NAs you can spend 20k on the motor and make all of 10-15hp, its just not worth it for anyone with any sanity. that link i posted on the first page (for those that can view it) is a perfect example, hes spent over 20k on a 30DE and makes about 25kw more than a 30E with an exhaust
best thing P platers can do is save up all their money and wait until they're off P's
You can spend 20k on anything and get poor results if you make bad decisions. 20k on an NA RB should easily be around if not over 300hp.
The point is this is not a turbo vz NA thread. It's an NA thread in the NA section. Stop talking about turbos in it.
And Jonno yes I have been driving the NA far too much and for far too long, lol, turbos are money pits too.
Sensible decisions are left at the door when you are into modified cars. My advice is waste your money making your NA go faster, have fun and learn lots. Then when you're finished your P's sell it at a loss and waste your money on a turbo.
Yes thank you rb26zed
Im not looking for people trying to convince me turbos are a cheaper way of more performance.
i know that this is true, but i dont want a turbo or i would of made a thread in the how to turbo a N/A section?
commodore or falcoon? its not all about power the main reason everyone buys a skyline is handling and brakes.
so when u can get a VN with cut springs that are zip tyed in to handle like a 33 with coilovers and a camber kit send me a PM
I love what you are thinking about doing. Personally I would use an rb30 bottom end with 25de pistons it will pump the compression up and they will be very cheap if you have to pay for them at all.
use the stock rb30 oil pump just make sure its ok, a quick inspection will fix that.
Bolt the rb26 head on you have about 10.5:1 now
use the itb,s for that look so cool factor and the lovely noise they will make.
Your going to have to fork for some decent cams to help it pick up the mid to top end range. As long as you dont rev it to hard this engine will be reliable and go very well.
You will not be able to run it off a 26 ecu but if you get an de-jetro power fc it should do it just fine.
get a set of rb30 headers and cut the flange off you will be able to weld an rb26 flange on there the port spacing is the same and away you go.
It will be an awesome project dont let people convince you other wise. Sure its not going to be as fast as a boosted engine but it will be way cooler for sure and the sound will make up for it
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
