Hey all,
Up for sale is my wrecked HR32, black in colour. Car was written off, damage to the rear end.
Pretty much it's a good condition front cut.
Car is standard apart from NEO6 turbo (OP6 exhaust housing). Engine ran great, gearbox is very good with no problems shifting at high revs. Gear knob not included :)
Pictures: http://s50.photobucket.com/albums/f345/niZmO_Man/HR32/
Price: $3,000 pick up only.
Car is located SW Sydney, NSW.
Please contact me via PM.
https://www.sau.com.au/forums/topic/347246-nsw-wrecked-black-r32-gts-t/
I wish I could part it out, but moving houses etc. etc. need to sell it as a whole.
If I had a choice, I'd put engine+gb into my R31, but alas I can't.
Only thing I can take from the car is the gear knob :(
Also, sunroof never leaked, worked perfectly. I miss it muchly :(
dude wtf happened to ur car?
if u do part out, im keen on both front indicators, RH head light, outer door weather seals / trims top and bottom, demister vents,
cheers damo
Dad wrote it off haha, I guess he should've made friends with HICAS before driving in greasy conditions...
Bump, price is negotiable. Car is a Type-M, although previous owner put the standard front bar on after damaging the Type-M one.
Edited by niZmO_Man
  • 4 weeks later...
  • 1 month later...
