Hi guts.
Taxi driver reversed and hit my front left side.
Lots if scratches including light.
Going trough insurance. Just wondering if anyone knows a good reparer in Perth.
Thanx
Alem
Oh no, Alem. Not another V. :(
How bad is it? Photos would help, mate.
What insurance are you with? I am with HBF now. When I got hit at the back by L-plater 2 years ago, I went to Uneeda Smash Repair.
Uneeda Tyre & Smash Repairs
36 Hogarth Street
Cannington WA 6107
Ph: 08) 9458 1521
Fax: 08) 9350 5645
Email: [email protected]
They did a great job for me. You could try giving them a call. Let me know if you need anything.
Good luck, Alem.
Edited by Victor.T
https://www.sau.com.au/forums/topic/347250-got-hit/#findComment-5588188
Good luck with the repairs, hope it doesn't get stuck at the workshop too long.
I am afraid it will be stuck for longer than usual as around Christmas/New Year is the worst time to chase up parts and people.
My accident was also around this time 2 years ago, and I only got back the car in early February. :(
hey mate you could go to instyle customs in bibra lake get my stuff done there and ruben does a good job. they won best custom paint at auto salon i belive too
Yeah, that green silvia won it. They seem like a good place for paint.
https://www.sau.com.au/forums/topic/347250-got-hit/#findComment-5589390
Do it.
Get them to do a custom paintjob whilst your at it, because your car has "a unique paint code which was custom mixed, and cannot simply be patched."
It'd be awesome if that worked :(
https://www.sau.com.au/forums/topic/347250-got-hit/#findComment-5589397
Do it.
I don't know how hard paint matching the silver colour is, but my pearl white looks ok. After a month or two in the sun, wash and use of clay bar, can't really tell the difference that easily.
Alem, FYI. Here's most of the paint codes/colours. Good luck.
2006
AY2-Garnet Fire
B21-Medium Blue
B30-Lakeshore Blue
BW5-Twilight Blue
K23-Liquid Platinum
K32-Serengeti Sand
KH3-Black Obsidian
QX1-White Pearl
WV2-Diamond Graphite
2005
KY0-Brilliant Silver
B21-Athens Blue
B30-Lakeshore Slate
QX1-Ivory Pearl
K32-Serengeti Sand
AX6-Laser Red
KH3-Black Obsidian
2004
B16-Caribbean Blue
KX6-Desert Platinum
QX1-Ivory Pearl
AX6-Laser Red
KH3-Black Obsidian
BW5-Twilight Blue
2003
QX1-Ivory Pearl
KX6-Desert Platinum
B16-Caribbean Blue
AX6-Laser Red
KH3-Black Obsidian
https://www.sau.com.au/forums/topic/347250-got-hit/#findComment-5589421
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
