I thought Id give the mod list not so lay now
TE37s 17s Potenza R comps at front
GTR hood, Grill and bumper
HKS hyper max 2 coil overs
Pine apples
Custom Oil catch can
Kensei Struts front and rear
Project Mu 2 peice Rotors
Apexi N1 exhaust 3 inch
Braided brake lines
GTR fron and rear interior
HKS Front mount
M spec duel alli Rad
RB25 turbo yay :/ soon to be TD06
Bosch 044
OS Gieken 1-2-3 cut gears
1.5 way diff (brand unknown)
Profec Eo1
Nistune
polished rocker covers, plenum, intake, brake lines, heaps other things polished
Cusco brake cylinder stopper
few others
I cant take all the credit on these mods though Orginal owner did really well Thanks Adam i will look after this car
https://www.sau.com.au/forums/topic/347253-hi-guys/#findComment-5588840
recommendations from friends my main concern atm is to replace the turbo that is just rooted on the car , anyone have a rb25 turbo?
stock one? i got a neo turbo. Op6 rear housing selling for $400. Pm me if interested
https://www.sau.com.au/forums/topic/347253-hi-guys/#findComment-5589981
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
