if you can find 3 local tuners who can tune, recommend and use it and can offer a reasonable price for install and tune go for it. there is no point picking an ECU that no one can tune, so best you check before anything.
my advice do like everyone else
powerfc
nistune
vipec
should be lots of local tuners, good options, good pricing as you can choose the tuner etc
fkn megasquirts is all ill say.
Ive added them to my no touch list as all the owner built ones seem to come in with a plethora of issues.....
there are much better ecu"s out there, i had a mate try 1 in his datto w/CA18..........it was a nightmare to setup as he used a ford ignition w/crank pick up and there was no tech support as they are based in england (so you have to call them at crazy hours).
stick to what has been tried & tested - Vipec/Link, Power FC, Nistune. at least all these are plug & play ecu's. there are plenty of people out there that have a lot of experiance with them.
Megasquirt is a good ecu but you have to have someone that knows what he's doing to work on it. A friend of mine got one in his BMW that made 390+ rwhp and 390+ torque. Car is insane, but.... i wouldnt put it in my skyline, too much hassle to make it work on a RB motor.
for what it's worth any ECU can make power, any ECU can make 100rwkw, 200rwkw, 800rwkw, 1200rwkw
how the ECU is tuned, the car, the usage requirement, it's usability, how it installs, features, support when things go wrong, price and availability of tuners is what is the deciding factor when choosing an ECU
so forget how much power a guy can make using an ECU
megasquirt is a owner made ecu for tinkering around and just having a mess around, great if you want to add loads of custom features yourself or are making an old carby car ecu but if you are not doing it yourself all you are doing is making it impossible for the tuner for no gain, generally they aren't a very good ECU and I would say its a large downgrade over a nistune.
Nistune is what I'd recommend for a near stock car, cheap, looks standard, no new wiring, simple to tune and large amount of tuners available.
^^ exactly they are generally fine with owners who have a clue about wiring and electronic principles, in fact give good results on the cheap as the owner can get most parts (triggers sensors etc from wrecking yards)but the the problem is most people with no clue see the price then buy it. try install it... fail then drop it to a workshop to sort out.... which is a night mare for us as often it is cheaper and easy to rip the lot out stick a std loom back in nistune it...
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
