1998 Subaru WRX Club Spec Evo 2 INTERESTED IN SWAPS ! ! !
Modifications:
Forged Oversize Pistons.
Forged Rods.
Arp Head Studs.
Steel Head Gaskets.
ACL Race Bearings.
Apexi Turbo With P20 Housing.
Process West TMIC Kit.
TURBOSMART Super Sonic BOV.
Side Feed Billet Fuel Rails.
X-Force Dump Pipe.
JASMA Canon Exhaust.
Microtech LT10 Computer.
E-Boost Street Boost Controller.
STI 4.44 Ratio Gearbox.
EXTREME Extra Heavy Duty Clutch.
EXTREME Lightened Flywheel.
King Springs.
STI Bonnet Scoop.
18inch ANZ Velvet Wheels Powder Coated With New Tyres All Round.
JVC Double Din DVD Unit.
Kicker Cross Over Speakers Front&Rear.
Kicker 4Channel Amp.
Bap Points: Rear Bar Needs Atidy Up.
Approx: 3000kms Since Rebuild.
Car is in run in tune atm. Making 150KW at all 4 wheels on 8pound boost. Car is now run in ready to be tuned after injectors upgraded.
Contact: Sel 0432336944, txt me your offers.
https://www.sau.com.au/forums/topic/347347-1998-wrx-club-spec-evo-2/
yea man it does. and then wen it comes time to let go nit many people realise!!! id be able to put maybe 2k ontop of mine but thatd be it. :) basically if i dont sort out a sale in the next week or two its gunna be parted out :(
Good luck with your sale mate! :)
over the water in tassie mate :) im pretty keen for a change
its a perfect platform for a pretty nuts car really got all the bits the tuneability of the vipec is incredible.
my 1st car was an R32 so i basically know the car in and out, how could we view each others car in a cheap way lol ?
thats the only frustrating thing now ahah
mine has one one lil issue that must be said. it has an issue with blowing a tiny bit of oil after decel so have narrowed it down tto valve stem seals. ( i just cant be bothered mucking round with it nemore :( )
so car wouldbe as is.
im willing to maybe go upto 2500 because of this issue..
yea man im an honest guy been screwed over today actually in a sale. hence the price drop. ha umm i could make a video and email or something? save flying? but in saying that flights a very cheap atm
yeah i got srewed when i bought this car, stock as a rock and the head gaskets went on me -_- , well what do you want too se of my car, any specific pictures, videos? i'd like to see more bigger and detailed pics of you car engine bay and interios, maybe a video of how it sounds ?
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
