thanks boys
I live at findon doesnt metter where about are they
ok
anyone has gtr from u guys, where have u got it tuned in adelaide and what mods and how much did u make and what boost,fuel mixture and etc.
I know about willal but dont like those guys
anyone else?
again thanks for big renspone
https://www.sau.com.au/forums/topic/347353-hi-i-need-help/#findComment-5589953
I will jump on and ask, need a good tuner north side of the city, prefer to be familiar with greddy emanage ultimate setup?
Try calling up Boost worx/Morpowa/Fours and More/Graham West Workshops. Call them up and speak to the tuner as to what you want to get things done etc.
thanks boys
ok
anyone else?
Well since willall is out of the picture, give shaun at boostworx a call or brett at graham west. these guys really know their imports and do a decent tune. Call them up mate its your best bet
https://www.sau.com.au/forums/topic/347353-hi-i-need-help/#findComment-5590051
i'll be another to say give fours n more a call, have worked on quite a few GTR's with great results and have tuned and worked on my 25det for the past 3 or so years and it hasnt missed a beat which is a rare thing for a drift engine. Speak to Brenton down there and let him know Luke with the S13 silvia sent you to him, phone number is 82602011. They are in pooraka.
https://www.sau.com.au/forums/topic/347353-hi-i-need-help/#findComment-5590195
thanks boys
ok
anyone else?
Boostworx
Have had my ca18det, rb20det, sr20det and also rb26dett tuned there over the years and never had any issues. There's always GTR's in the workshop so they definetly have RB26 experience.
My R32 GTR was making 314.7rwkw @ 19psi with R33 engine, -7 (N1 turbo's) 550cc inj, bosch 040, power fc, sard fpr, standard afm's, turbo back exhaust etc.
https://www.sau.com.au/forums/topic/347353-hi-i-need-help/#findComment-5590419
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
